Suggestions for my warning switch and valve covers?
Discussion in 'Technical' started by Hairy W Bush, Jan 15, 2018.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    A couple different issues I'd like to try and solve in this 1 thread.
    #1 I bought this proportioning valve https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/231631393689
    My brake light warning switch connector does not fit that switch. Same shape but it's dumb, the connector is slightly smaller enough to not go on at all. I don't t have my old switch either. The seller says he can't get a pigtail and I can't find one either. Luckily I have not filled my master with fluid yet just in case.
    My second issue is I have Holley valve covers with twist style holes. Well of course that's a problem with a pcv valve. I have a new pcv valve into a twist style grommet....but it leaks. I applied Permatex #2 to the hole and grommet and it still leaks. Do I have to silicone this? I'm wondering why I can't find a proper solution talking to anyone considering how old these covers are.
  2. Krazy Comet
    Dismal Swamp
    AFAIK the switch doesn't seal anything, just a switch to turn on brake light if pressure is low on one side of system... Back in '70 & '80s almost all cars had a brake light burning, if valve moved it would seldom reposition itself...
    Dunno what to say on the VC, I have the chrome repop Power By Ford on my Comet with twist in PCV adapter, doesn't leak(at least noticeably)...
  3. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Yea it's just something I'd like to have working properly.
    Can you expand on your adapter and how it works? It's not a grommet correct?
  4. 71gold
    you may need to install a baffle under the PCV hole so the rocker arm doesn't throw oil on the G/V.
  5. Krazy Comet
    Dismal Swamp
    Do you mean with this type filler?? If so the '68-'69 390 & 428 used a twist in grommet with ears... Mustang/Torino etc vendors should have it...
  6. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I do I made one
    yes and yes that's what I was talking about. it leaks. can you point me to what you actually have? I hate to buy ANOTHER pcv but I can't have this leaking like this.
    also, does this look like what came in our MAvericks?
    https://www.ebay.com/itm/Ford-Musta...ash=item282fc9f724:g:GPAAAOSwJtdaECXd&vxp=mtr
    if so I need to order it asap
  7. Krazy Comet
    Dismal Swamp
  8. Hairy W Bush
    Hairy W Bush Member
    Georgia
    yup that's what's in there.
  9. Hotrock
    Munroe Falls, Ohio
    With a properly functioning baffle you should be able to leave your PCV valve completely out of the grommet and not have excess oil migrating onto your valve covers. How many miles and in what condition is your engine? From the description of your engine's PCV system leak, it would appear you may have excess blow-by into the crankcase thus causing internal pressure resulting in oil forced by the grommet and onto the valve covers.
    Just a thought.
    71gold likes this.
  10. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I know. But I cannot divulge into that at this time. But it is happening only after a drive.
  11. Hairy W Bush
    Hairy W Bush Member
    Georgia
  12. Hotrock
    Munroe Falls, Ohio
  13. Hairy W Bush
    Hairy W Bush Member
    Georgia
    it's a twist. i'll have to modify it a bit. i'm in the process of moving and I just need this car to move.
  14. Hairy W Bush
    Hairy W Bush Member
    Georgia
    switch came in and that doesn't fit either...great.
