Suggestions for starter/alternator replacemtent
Discussion in 'Technical' started by scooper77515, Apr 9, 2006.
  1. scooper77515
    Good point...
  2. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I see I'm not the only one with the alternator thing going on right now. I just don't understand why the one-wire hook to the battery is the same as the factory alt. with three-wire connections. How do they do the same thing?
  3. scooper77515
    I think the other wires are back and forth to the external voltage regulator, where the one-wire has the voltage regulator inside the alternator.
    Not sure if that answers your question...
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Yea, I think that might do some good in the brain. I thought those wires went to the fuse box or something like that. If you do the one-wire alt, what gauge cable do you run to the battery?
  5. scooper77515
    i am using 10, but some have said 8 is better. That is from the alt to battery. 2 or 4 gauge from battery terminals to ground and to the starter solenoid.
  6. bmcdaniel
    The 3-wire models have remote voltage sensing and operate an idiot light. They are a little more accurrate in supplying the correct voltage to the rest of the car (think computers), but they have an internal regulator just like a 1-wire. Unless you're running EFI you don't need to worry about it. My 1-wire puts out 15 volts all the time. Charges the battery quicker and the lights are brighter.
  7. scooper77515
    Is "idiot light" the ALT light on the dash?
    When I cut the main hot wire from the alt and hooked up the new one to the battery, the car ran but the ALT light on the dash came on. I didn't test it, but is that what the little spliced off wire from the main hot recharge wire goes to?
    I would like to set the new one up so it still activates that light if anything goes wrong.
  8. Graybeard
    Graybeard Member
    Lawrenceburg Indiana
  9. bmcdaniel
    Informative article. Funny that he makes a point about not needing to push one type of alternator over another because he doesn't sell alternators. But he does sell the 3-wire "kits" for which he charges $27 for, well, 3 pieces of wire. :rolleyes: Still is a good article, though.
