SuperGrabber
Discussion in 'Maverick/Comet Projects' started by MaverickConnect, Feb 14, 2009.
  1. MaverickConnect
    MaverickConnect The Maverick Connection
    Parkersburg, WV
    1971 Grabber, & 1971 SuperGrabber
    Apparently I'm out of room. I emailed Stefan to see what he could do.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. MaverickConnect
    Parkersburg, WV
    SuperGrabber Update Pics
    Okay, re-upped my support. Let's try again. Hope it's not too soon...
    The first and third pics give you a better idea of the motor set-back and the overal suspension setup. The bags are not on it here. The fourth pic shows air cleaner choice will be limited! I'm even worried about a 4-barrel clearance! The fifth pic shows the steering joints Jack fabricated.
  4. MaverickConnect
    Parkersburg, WV
    Let's try some more...
    Here, the first picture shows how little clearance there is for headers. The third pic gives you an idea why a big block is out of the question due to the narrow frame rails. The fourth picture shows why a master cylinder in the usual location might be a problem! Ha, ha, ha.
  5. MaverickConnect
    Parkersburg, WV
    In these you can see how the trans tunnel turned out, coming close to finishing the interior fabrication. The last pic shows how tight header clearance will be on the passenger side too.
  6. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Here is what we started with,It's coming along nicely now,can't wait to hang a rear under it and get it down on the floor to see what it sits like,we"ll keep you posted ...Jack
  7. mav1970
    Jack, Seeing your photos of what you started with, I see what looks like no front frame rails at all. When you fabricated your new 2 x 3 rails, what did you attach them to?
  8. actionrpm
    western pa.
    If you look close at the pics,there are two 2x3 rails sticking out angle cut at the floor,that is why the down tubes were put in ,back to the cage to support the front clip,I fish plated the joints for strenth also.
  9. Dave B
    Really Nice! I can't wait to see it in person, someday. I really like how the lower crossbar blends into the bottom of the dash panel.
  10. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    Boy lots a work there but in the end it should be one amazing Maverick.
  11. CaptainComet
    I have been following this thread with great interest ... awesome work going on here.
    Every problem is an opportunity in disguise ... think old-NASCAR-style air cleaner sealed up to and breathing from the cowl vents.
  12. ModMav71
    ModMav71 Member
    Sebring, FL
    Is the Mustang II crossmember for an early model truck?
  13. MaverickConnect
    Parkersburg, WV
    I was thinking the same thing!
  14. sierra grabber
    sierra grabber Certifiable
    northern nevada
    my K&N stopped clearing when i put the edelbrock manifold under it so i ordered a 1 inch tall circle. if you think you are going to be much higher you may have to do some fab work on the filter. captaincomet has a pretty cool suggestion for that.
  15. actionrpm
    western pa.
    It was custom built for this job and is 3" narrower than standard width,the rack was narrowed also to avoid "bumpsteer".
