suspension help
Discussion in 'General Maverick/Comet' started by GreyGhost74, Sep 26, 2014.
  1. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Guys when it comes to suspension parts I'm lost. Is this a shock or a strut?
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
  3. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Do I need a spring compressor to replace that ?
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    No, remove the two bolts at the bottom and three on top of the shock tower and it will pull out the top through the engine compartment.
  5. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    You have no idea how happy I am to hear that lol. *sigh*
    I got the tool anyways, but I will happily return it....
  6. RMiller
    Kennewick, WA
    It's pretty easy other than those nuts at the bottom, they can be a pain but if you soak them good with penetrating oil it will help.
  7. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
  8. mav1970
    The shock comes out easily as mentioned but if it is the coil spring you need to remove, a spring compressor is absolutely needed :)
    GreyGhost74 likes this.
  9. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Yeah I have the car jacked up and weight off the spring and the control arm and it looks like its blocking the rear shock bolt because there's no weight on it. Can't get a socket on it. Any suggestions on how to remedy that?
    Or maybe its just a pain to get off, LOL
  10. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Figured out the problem. You either have to remove the bolts before you jack the car up or take out the back one first if its already in the air. Both new front and rear shocks are in. My rear air shocks were shot. Right side was totally collapsed. Rides a lot less bouncy now lol...
  11. mav1970
    How long has you car had air shocks? A lot of members including myself have had bad experiences with air shocks ripping the top mounts out and driving their way up through the trunk floor :slap:
  12. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Honestly they look like they've been in there forever. But the mounts look good. And I replaced them with standard shocks
  13. mav1970
    Just too many bad stories about air shocks - still good you changed to the stock shocks - much better to add a leaf or have them re-arched if you ever need some extra height
  14. CaptainComet
    If the air shocks leaked all the air out, you can run them for years without ripping out shock mounts ... ask me how I know that .... They work like regular shocks then.
  15. mav1970
    Unless you are raising the back of your car to clear big tires by using air shocks, the air leaks out, the fenders hit your tires------ask me how I know that :LOL:
