Swapping 302 for a 351
Discussion in 'Technical' started by MAVNWOT, Oct 3, 2005.
  1. Jamie Miles
    Alto, GA
    I've had a few
    Don't let the size fool you, a 351M would never be worth messing with. My grandpa has a '78 Bronco with one. Slow, 70's emissions junk motor. I wouldn't even put one in my truck or car if someone gave it to me...
    The '86 GT motor shouldn't be to much of a problem. Main thing is if you are going to use a C4 you gotta get the correct balance flywheel and stick a carb intake on it. I believe you also will have to put a front sump oil pan on and change the timeing chain cover so you can put the mechanical fuel pump on. Or you could just run an electric fuel pump. Also gotta work out what you want to do as far as the serpentine belts and getting the correct water pump.
  2. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    1972 Ford Maverick, 302 w/ B&M tranny, everything else is stock
    thanks for the advice man
    1) on the 86 GT motor, could i keep it fuel injected? cause thats really like to keep it that way if at all possible..
    2) on the oil pan situation, could i just take off my oil pan that i have on my 302 and put it onto the 86 motor w/ no problem?
    thanks again :thumbs2:
  3. Jamie Miles
    Alto, GA
    I've had a few
    If you want to go through the work of wireing it all up then yes you can run EFI. Several guys here are. Oil pan should swap I believe but don't take my word for it...
  4. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    cause ive been thinking bout switching motors w/ my friend....hes the 1 w/ the 86 stang on my site (link in the sig)...since he will be going to a carb'd engine next yr
  5. Jamie Miles
    Alto, GA
    I've had a few
    Why dosen't he just change the intake on the engine thats in there?
  6. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    no clue..he already has 1 engine being built by him, but idk
