Sway Bar Bushings
Discussion in 'Technical' started by demo913, Jan 4, 2010.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    When I change the front sway bar bushings and end links should the front be jacked up or on the ground? I've heard both. Thanks
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    With the car on the ground it's easier for me. It can be done either way.
  3. Mavman72
    Roll the front up on some drive on ramps...Lots of room that way...:yup:
  4. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    The ramps is what I was thinking too. I had just been told you need it on the ground for proper alignment with the control arm. Guess thats not so true...
  5. Corbin Johnson
    With the wheels on the ramps, the control arms will still be approximately in the same place as if the car was on the ground. (y)
  6. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Ok. So yea the ramps are the way to go when changing. Thanks for the replies...
