T-5 swap ?
Discussion in 'Technical' started by mavgrab302, Apr 27, 2013.
  1. mavgrab302
    1.What are you using for a trans cross member for your t-5 ? can I buy one that doesn't need fabbed or welded ?
    2. Dose the original starter still work ? Or do I need to by a new one...
    3. Will the drive shaft need a new yoke ? or shortened ?
  2. Bryant
    ive made my own crossmembers but 71gold sells one that works
    need a different starter usually
    no need to do anything with the driveshaft.
  3. 71maverickGT
    71maverickGT Member
    NY
    71 maverick gt
    driveshaft will work fine. if you plan on running some serious power get a custom one made you can use the stock driveshaft measurements as a reference to get a better custom one made. you can either modify your original crossmember or buy one off 71 gold. your gonna need a welder too. i finished mine up recently been pulling holeshots on my street my neighbors hate me :rofl2:
  4. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    I modified my cross member, the drive shaft is reusable and the starter will be the same out of a fox body
  5. Streamliner
    Streamliner Member
    This....If i remember correctly i cut the 2 ends off, flipped them upside down and re-welded....Might've had to elongate the mounting holes a little but it worked perfectly
  6. mavgrab302
    OK, I'll order a fox starter... The part # on the trans says it was for years 85-90 so a starter from those years will work ?
    I knew Frank had a cross member kit, I was hoping to buy one that was ready to use without welding.. Oh well I guess I can't have everything...lol
  7. mavgrab302
    I just thought of another question... What is the angle I need to set the engine and trans at, when making the cross member ? should I match what the angle is now ?
  8. Jamie Miles
    Here is what I did to mine when I put an SROD in. Should work for an AOD or T5 as well. Been holding up well for about 2 1/2 years of daily driving now. It was just pieces of 1" and 2" flat stock I pulled out of the scrap bin at work. Clamped the 1" piece in a vice and used a torch to heat it and put the 2 bends in it. Used a grinder with a cut off wheel to cut the slots in the 2" piece, then buzzed it all together. Anyone should be able to replicate it in a couple of hours with a welder and basic tools.
  9. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
  10. mavgrab302
    Cool so you just extended the area where the mount go's ? No change in the hight ?
  11. mavgrab302
    I'm confused about the flywheel I need... I know I need 28oz external, but for my 74 302 do I need 157 tooth or 164 tooth ? both come up in my search...
  12. Dave B
    It comes ready to bolt in, no welding required.
  13. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
  14. mavgrab302
    I just found a factory 157 tooth flywheel in the garage, will this work for the t-5 ? It's amazing what you find that you didn't know you had...lol...
  15. turbotbird23l
    turbotbird23l Member
    kennesaw ga
    75 mav 87tc e36
    what are you doing about the pedal assembly? or did you have a manual already and going to the t-5?
