t-5 transs convertion
Discussion in 'Transmissions' started by Eliud71, Jan 1, 2009.
  1. Eliud71
    Eliud71 Member
    Puerto Rico
    comet 1971 5.o mustang engines 1990
    :dance:!Happy new year everybody!I live in Puerto rico , i have a comet 1971,5.0roller engines 1986for a mustang gt,i need helph whith i can change my c-4 for a t-5 manual transs,the crossmember,the clutch cable,the driveshaft,and the tunel ram,what i nedd to this changes:idea:
    thanks for a helph,Eliud:thumbs2:
  2. mean_maverick
  3. starsky74
    starsky74 Technician
    Hackberry Louisiana
    Ok, no matter what bs people tell u( no offense anyone) u can use a stock maverick v8/c4 trans crossmember. How do i know, ive done it! u have to use the c4 mount and crossmember, they bolt up to the t5 like it was meant to be. The trans tunnel on the other hand is a different story. it will take a little massaging and a cut off wheel to get room for the shifter and housing. if u have a 2 door, u can use a factory fox body drive shaft, not sure if years make a difference, but mine came from an 86 notch stang, u have to hunt down an oddball u-joint for the rear, but thats not that big of a deal, we found one at autozone they had in stock!
    good luck and have fun!!!:thumbs2:
  4. mean_maverick
    yeah, if u cut out the trans tunnel brace and a spot in the floor then u could prolly use the stock crossmember. personally, i didnt wanna take any of the bracing out of my car so i just made my own mount
