T.D.C. & Rotor Posistion
Discussion in 'General Maverick/Comet' started by Micwayhan, Aug 22, 2014.
  1. Micwayhan
    Micwayhan Member
    Inverness, Fl.
    1974 Mercury Comet 4-Door
    I was wondering if I have this correct. I have cylinder 1 at T.D.C. & (0) at the timing mark, the rotor is set on 1 in the cap. It's been a while so I just want to make sure I did this right, thanks for any replies.
      File size:
      55.9 KB
  2. 71gold
    only if it's on the compression stroke.
  3. Micwayhan
    Micwayhan Member
    Inverness, Fl.
    The piston in 1 is at the top of the cylinder, would that be correct?
  4. mojo
    That is correct!
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    The piston will be at the top of the cylinder, but you may not be on the compression stroke. Make sure you're on compression before setting the distributor in or it may not start.
  6. Micwayhan
    Micwayhan Member
    Inverness, Fl.
    Thanks for the help guys
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    If you have the balancer on with a timing pointer, align it to 8 - 10 btdc, or whatever you set your timing to. Then insert the distributor pointing at #1 cylinder. Once you start it you can use a timing light to get it closer.
