T stat ?
Discussion in 'Technical' started by mavgrab302, Dec 25, 2011.
  1. 71gold
  2. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
  3. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    I use 192/195 thermostats in the Comet, Maverick, and Mustang.. Havent had an issue yet.
  4. 71gold
    in my Mav, I just removed a...160...and replaced it with an...86C...(makes heater more better...:yup:
    the 160 carried a...160-163 temp range.
    the 86C carries a...188-192 temp range.
    ...:yup:...
  5. Joe Dirt
    Here is my .02
    I swapped from a 187 to a 160 in my lsx I didn't change the tune
    Before. 20mpg. 187-195* operating temp
    After. 14.5 mpg. 165-170* operating temp
    Just throwing it out there this was around a half point in the afr differance at cruise
    If you gain power going cooler you need to work on your tuneup
    Hot fluids (oils) make more power (less drag)
    Hot fuel makes less power
    Cool coolant fights detonation
    Up to temp coolant provides effeciancy
  6. 71gold
    now that you mentioned it...i noticed a drop in MPG also with the 160...:bouncy:
  7. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    yeah all cars run better at the dragstrip when its at least a hundred degrees they always get slower at night when it cools down:rofl2:
  8. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    i always heat my gas when its a hundred degrees outside at the dragstrip too and when i do i use a heat can instead of a cool can:bananaman
  9. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    I ALSO BLOW HOT AIR FROM MY RADIATOR RIGHT INTO MY COWL INDUCTION HOOD IT HELPS MAKE MORE HORSEPOOWER:chirp:
  10. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    and after my cars real hot from running the guts out of it i always blow hot air on the radiator because i want to have increased bearing life. I always see my friends do that too after they run cars hard especially at night when the tracks coooled off you just can't have enough heat in an engine:thumbs2:
  11. 71gold
    ...TOO Funny...:rofl2:
  12. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    I also like having heating pads under my air gap manifold to help with the horsepower and I wrap my headers so the heat will stay in my engine I also run a griffin 3 row radiator because i like very hot engines it helps horsepower and I run a high volume water pump so my engine runs as hot as possible and i run a spacer block under my carb because i love hot fuel my car does too because everyone knows heat makes horsepower:rofl: I also run a electric fan too so my car stays as hot as possible
  13. 71gold
    ...STOP!!!...you're killing me...:rofl2:
  14. Joe Dirt
    Lol. So what's your car run?
  15. Joe Dirt
    Probly gonna be down you way Tuesday (summit)
