T stat ?
Discussion in 'Technical' started by mavgrab302, Dec 25, 2011.
  1. mercgt73
    If the hose got hot, then most likely the thermostat opened. 7 degrees is not that far off, given the non-perfect thermostat and temp gauge. Also, if the gauge sender is in another location than your thermostat housing, the coolant temps could be different.
    If the hose is cool, the thermostat is not open. Or you are not pumping coolant, but that usually works just fine.
  2. mavgrab302
    The sensor is in the t-stat housing and my gage is a summit digital electric... I also bumped up to a 16 pound cap, because with the 13 it would puke the coolant out of the over flow... My 302 powered mustang did the same exact thing, I dont know why tho....
  3. Joe Dirt
    It would be better to move it pre thermostat and be more accurate along with giving a safety cushion if the thermostat was to fail
  4. mojo
    My sensor in the intake manifold w/ Autometer mech. gauge.
  5. 71gold
    it may be...air locked...did you drill a burp hole in the T-stat before installing it?
    ...:drive:...
  6. mrbrooksy
    mrbrooksy Retread
    Motor city
    72 maverick,99 cherokee,2000 cherokee.80 suzuki ts 250 and a minivan
    hot enough to burn your arm when you lean on the rad
