t5 tranny swap
Discussion in 'General Maverick/Comet' started by rpankoff, Dec 5, 2014.
  1. mojo
    Here is a link to one that may interest you? I purchased it last fall, haven't had a chance to use it yet. I think it will work gud for our type suspension, though I have not used it yet.
    http://www.ebay.com/itm/like/261195370724
  2. 55crownvic
    55crownvic Member
    colorado springs
    Is there an advantage to using 5/16" brake line over 1/4"? Like maybe an easier pedal to push, or more travel of the slave cylinder?
  3. Bryant
    not that i know of. i guess it could allow for a larger volume of fluid to move through the system faster. i dont think its needed.
  4. rpankoff
    rpankoff Member
    racine,wi.usa
    70 maverick,57 ford,65 mustang
    Hi Bob here again,On my sons 70maverick that he's trying to put the t5 tranny in.This is what he did.Put the trans. In with the t5 bell housing,new clutch,plate,throwout bearing,cross member,driveshaft installed.Does anyone know of someone in the Wi.area that could give us a hand in finishing it?Linkage needs to be installed along with the maverick pedals.Every time he brings someone over to help he takes something else off.I need someone that knows these cars and can do it.Please let me know thanks Bob
  5. rthomas771
  6. bmcdaniel
    What kind of linkage is he trying to use? The T5 bell housing release fork has to be pulled towards the front, traditional mechanical linkage pushes the fork towards the rear.
  7. 71gold
    this is the one I use...I rent it from Advance Auto...:thumbs2:
  8. rpankoff
    rpankoff Member
    racine,wi.usa
    that spacer block they talk about is that to be used only if you have the z bar set up or with a cable system only.Thanks for the help Bob
  9. bmcdaniel
    Use the spacer with a z-bar setup AND an old bell housing. Later stock-type diaphragm pressure plates are shorter than the original Long-style pressure plates our cars originally came with so the release fork pivot point has to be moved closer to the pressure plate to keep the linkage geometry correct. All you need to do is get an aluminum or steel block and drill a couple holes in it to make a spacer. In my case, I have z-bar linkage but I used a CenterForce diaphragm clutch that is a taller, exact replacement for the earlier clutch. No spacer needed. But I'm using an old bell housing where the release fork gets pushed to the rear.
    As mentioned up in post #21 a T5 bell housing, where the fork pivot point is at the far end of the fork, needs to have the release fork move forward. This is usually done with a cable or hydraulic cylinder.
  10. rpankoff
    rpankoff Member
    racine,wi.usa
    What if I go with a cable?Does anyone know what cable that i would need?
  11. rthomas771
    Cables will stretch and they will break...if it doesn't burn in two on the exhaust first. You will need to modify and install a quadrant on the pedal and hope it doesn't hit the bottom of the cowl if you go with cable. You will also need to use a diaphragm pressure plate with a cable. If you have room then I would stay with the factory mechanical linkage because for some reason or another it will fit right out of the box like it was made to fit your car and then you can use either a diaphragm or long style pressure plate.
  12. rpankoff
    rpankoff Member
    racine,wi.usa
    UOTE="rthomas771, post: 1040987, member: 8227"]Bob, This is how I done an automatic to 5t swap. http://1bad6t.com/Maverick/maverick_51.html Maybe you can get some info you need[/QUOTE]
    Just got done putting the pedals and z bar in but I need the ball that goes on the engine that slides into the bar,also I don't think my fork will work,and the clutch I put in is a fx stage 1 with a diaphragm pressure plate,will I still need that spacer and does anyone know where I can get the ball for the block and the right kind of fork.Thanks again for all your help.we are getting there.Bob
  13. rthomas771
    The factory fork will work. If you need a new fork buy a McLeod #16934. Any Mustang Vendor should have the z-bar ball and spacer. The t5 bellhousing is deeper so you will need the spacer block to relocate the fork closer to the pressure plate. Mount the spacer 1" from the edge of the opening. You can use any style pressure plate.
    [​IMG] [​IMG]
  14. rpankoff
    rpankoff Member
    racine,wi.usa
    Thanks again.i
  15. rpankoff
    rpankoff Member
    racine,wi.usa
    Another question,I also have hooker headers on the car and it looks like I'll have enough room for the z bar and linkage it looks kinda tight.any mods I have to do for it and also I had power disc brake set up on the car do I have to go manual disc brakes? Thanks Again Bob
