T5
Discussion in 'New Members Forum' started by rachjake, Sep 17, 2022.
  1. rachjake
    rachjake Member Supporting Member
    Pace, FL
    1975 Maverick
    Is it correct that a 1975 Maverick was not available with power brakes and a manual transmission ?
    Also, in order to install a T5 transmision, you must convert to manual brakes ?
    Thanks
  2. mojo
    Manual brakes are all that’s needed on these cars; if they’re in good shape car stops just fine. One advantage pb, maybe lower brake pedal. I have a 1/4” spacer between Mc & firewall lowering my pedal; some use adjustable pushrod.
  3. bmcdaniel
    Unless I'm missing something, the only reason I could see manual brakes being necessary is if the power booster interfered with the clutch linkage. There are ways around this.
  4. Powerband
    Powerband Member
    NY's \H/
    ... Also, in order to install a T5 transmision, you must convert to manual brakes ?
    ... if the power booster interfered with the clutch linkage. There are ways around this.
    I was wondering' the question , now it adds up.
    '74 Maverick 250 / VII SC - T5-Cobra Spec x-218 - Centerforce Clutch - 3.80Posi - '76 front spindles/NPdiscs - Bench Seat - AM w/rear speakers.
    Original 3OTT Clutch linkage with T5 bell and push' throwout arm adapter. With the T5 and 3.80 rear, there's a gear ready for back road carving to comfortable hi-speed interstate cruise with the T5's - 1 : .68 Overdrive ...
    [​IMG] .[​IMG] .[​IMG] [​IMG] . [​IMG] ..[​IMG] .
    wonderin' - '74 has the belt/ign . interlok - is it only '74?
    have fun
    mojo and Krazy Comet like this.
  5. Craig Selvey
    NO Mavericks ever came with power disc brakes AND a manual transmission. With the offset of the power disc brake rod, the clutch rod will not work ad it would interfere. As stated, I am sure there is a work around.
  6. rachjake
    Pace, FL
    1975 Maverick
    Has anyone had experience with installing a T5 into a 1975 Maverick with power brakes ?
    If so, what is the work around ?
    Thanks
