Tag in C4
Discussion in 'Transmissions' started by t.ramsey, Nov 15, 2014.
  1. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I found a green, metal tag attached to the valve body of my C4. Does anyone know what it is?
  2. 71gold
    is this a stock transmission...as in never been rebuilt?
  3. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I'm not sure. I bought it in '91 and only put about 20,000 miles on it. I never rebuilt it but it's very clean for having almost 90,000 miles.
  4. 71gold
    it should have had a plastic ball in it if it has never been opened.
  5. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I had it serviced when I bought it. There was no ball when I opened it.
  6. Krazy Comet
    Dismal Swamp
    Calibration/ID tag from factory, would be used by dealer to order VB parts or maybe a complete valvebody... Since it's still in place, trans has likely not been rebuilt(at least by the average independent)...
  7. t.ramsey
    t.ramsey Member
    austin,tx
    both
    Thanks
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    this is a tag that was on the same screw as the above green one. C4 was in a 1980 Granada, I250, from P&P, and was painted silver and very clean inside. Car had 140K so am guessing re-build. I dont have a clue what HO03 means......Any transmission gurus care to shed some light on it? I have no luck locating any info on the net.
  9. stuarta
    stuarta Member
    Moose Jaw Saskatchewan
    2008 Ranger
    See #6 above.
  10. Rasit
    Rasit Member
    SE Pennsylvania
    Why's that? I would think a lot of guys would reinstall the tag after a rebuild. I put mine back in after the rebuild.....
  11. stuarta
    stuarta Member
    2008 Ranger
    If a shift kit was installed the tag would be meaningless.
  12. Rasit
    Rasit Member
    SE Pennsylvania
    Gotcha. Thanks
