Tail lights? I had the car completely down and when I finished putting it together I had no tail lights the bright light indicator was on and the passenger light was really dim. Well I had done some painting and had created a bad ground. Now both head lights work still no tail lights.....the brake lights do work. And now in addition to that, the signal indicators are both lit and the high beam indicator can be turned on and off by changing from high to low beam. I'm looking for grounds that I might have missed and ones associated with the tail lights....also maybe the dimmer switch got damaged....I never removed it though. Oh yea...the side markers now flash with the hazards. Any input would help. Thanks, JC
