Tank Level Sending Unit
Discussion in 'Technical' started by Renton5, Mar 12, 2015.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    I have a '71 Mav, 200 engine. The gas needle doesn't always show the truth. Any suggestions on where I can get a replacement tank unit, hopefully American made? Also, where can I get a lockring tool? Thanks much!
  2. 71gold
    for the one on the sender...a drift and a hammer...:thumbs2:
  3. bmcdaniel
    Preferably a brass drift so you don't make sparks.
  4. 71gold
    good point...I use a large Snap On screwdriver...:yikes:
  5. Renton5
    Renton5 Member
    Van Nuys, CA
    Hello, fellow car owners! Thank you for the tip on using a hammer and brass bit to loosen the lockring. Any thoughts on where I can get a quality tank sensor? I saw a new stainless steel one on Ebay for $99, but I couldn't find who makes it.
  6. Renton5
    Renton5 Member
    Van Nuys, CA
  7. Craig Selvey
    I believe all the repops for a Maverick are made here in the USA.
  8. Renton5
    Renton5 Member
    Van Nuys, CA
    Hi Craig, I'm sorry, I'm not familiar with what "repops" is.
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    Reproduction
  10. bmcdaniel
    Make sure it's not just a grounding problem. My gauge acted flaky so I added a ground wire from the chassis to the sending unit, problem solved.
  11. bhellickson
    bhellickson Member
    S. California
    1970 x2 71x2
    I have had the units rebuilt -- I have never found and American made reproduction and have had really bad luck with them. Then along came tristar radiator. This guy sends your unit back PERFECT -- painted cleaned looks like brand new. Set it next to a repro and WOW what a diff. Price ranges from 75- 150 is depending on the condition of your unit. They are tested 6-75 ohms and calibrated. BEST way to get your sending unit replaced (reconditioned).
    Dan OHora
    That Fuel Sending Unit Guy!
    1-(315)-712-0071 M-F 9am-5pm EST.
    Craig Selvey likes this.
