Tank Resivor For the Radiator
Discussion in 'General Maverick/Comet' started by doughboy91, Dec 18, 2009.
  1. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    The tank on my drivers side is the washer reservoir which I filled this morning and it works great.
  2. Blown 5.0
    MS.
    1974 Maverick
    A down flow radiator will never stay full to the top due to expansion of the juice, This is where a overflow jug comes in. When the juice expands and pushes out it has somewhere to go other than the street. Then when the juice inside cools ( and shrinks) it will form a vacuum and pull the juice in the overflow back into the radiator. As far as the cap,( ithink yours is bad) Water boils at 212 degrees fahrenheit. (at sea level) For every positive pound of pressure you put the water under it raises the boiling point 2 degrees. Example 7 psi cap raises the boiling point to 226 degrees.( this is with no antifreeze, which raises the boiling point itself) But now for my opinion, I see no reason to ever run any of my cooling systems over 7 psi because i don't run them anywhere near 226 degrees. So why should i be putting 13-16 psi of pressure on my heater core, Head gaskets, Radiator, Hoses, Etc. Not to mention if it does get to boiling with a 16 psi cap you now have water in the 244 degree range ( can you spell 3rd degree burn). I think the 16 psi caps were more intended to please the EPA than they were for function. ( i have heard the argument about steam pockets also) Although there may be a reason i haven't found to run a high pressure cap, I just haven't found it yet ( i know about nascar just have never had the chance to run one). As always this is just my opinion and others will vary.
  3. CaptainComet
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Pretty sure the standard replacement radiator caps for a Maverick will not allow overflow recovery.
    Your coolant level should remain 1 inch below the filler when cold and that is full ... even as per the owners manual. It should not be filled up to the filler opening all the time.
    If you are puking enough fluid that after it cools you are not 1 inch below the filler opening ... then you are having some sort of cooling issue. Mine is 1 inch below and I have never puked fluid ... and it gots hot here in GA ! My temp gauges is generally between 180 and 190 depending on moving or idleing.
  5. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    For all the crap my car was missing, it did have and over flow tank that looks factory original to me. LOOKS being the key word. was it a option? judging by the slicks that where on my car, im thinking the PO raced it regularly. So that would be a requirement for the track, Right?
  6. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    Yep, prior owner probably added it from another car if it appears to be a factory piece.
  7. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    And we do realize that we are talking in a thread over a year old right? LOL
  8. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    thats what is so cool about this site to me, someone comes along and drop there two cents and off we go.
  9. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    I got a nice ford blue plastic one from summit racing, and I like it alot! Sure is pretty sitting next to my aluminum rad.
  10. brainsboy
    brainsboy Member
    Tampa
  11. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    i would love to see a picture of that set up!
  12. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    1976 ford maverick 302v8
    At some point, don't even remember where, there was a sharp canister that mounted right next to the rad, and had a bracket, for the old fords. even has a ford engraved overflow cap... about 3" diam and about 1.5ft long, been looking for it ever since... lol! A lot of the older cars at most shows have them, keeps the show car from dumping coolant if there ever is an issue... my mav has only peed once, from overfilling and warming it up... had shut it off and there it went all over the driveway.
  13. mjm0395
    mjm0395 Member
    Everett wa
    So Summit racing has nice looking aluim. tubes the way you are describing them, I decided to go with the blue plastic as it was cheaper.
