Taurus fan upgrade and battery location
Discussion in 'Technical' started by jasonwthompson, Aug 7, 2016.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    My initial thought was just to get it cleaned up under the hood, but after seeing yours I think it is probably more trouble than what its worth.
  2. bmcdaniel
    You can move the solenoid down low in the engine compartment where it's less noticeable. I mounted mine at the lower hole for the battery tray. Screwed in a 5/16 (?) bolt through that hole from the wheel well to make a stud to mount the solenoid. That point is now the main ground location for everything including the battery (-) cable.
    jasonwthompson likes this.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Jason,
    If you put the battery in the trunk, I recommend the cable and the circuit breaker I referenced in my Showcase Post.
    Mciah
