Taurus fan
Discussion in 'General Maverick/Comet' started by smegnl, Sep 6, 2020.
  1. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    Just a good clean up and a rattle can makeover
    mojo likes this.
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Found 2 - 1995 Ford Taurus GL V6/3.8 about 40min away here in a pull a part. Gonna give them a call and maybe go up this weekend.
    According to Wicapedia the 2nd generation Taurus was made from 91-95
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Got lucky in one of the cars had the fan and shroud still. $28 out the door. Hooked it up to a battery and still spins very good.
    Will I be able to run this thing with the stock alternator? Figured at 2500CFM on low that should be good enough.
  4. ike72com
    ike72com Member
    Charleston SC
    Stock alternator barely support stock accessories in my opinion.
    Replaced all my fords with GM one wire. 100 amp!!!
    Ford stock might be 40amp i think.
    mojo likes this.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I also have a Taurus fan, but I did a Ford 3G 130 amp alt upgrade first. You may be able to run it with the stock alternator, but I sincerely doubt it. That looks like the 3.0 fan.
    71gold and ike72com like this.
  6. mojo
    You will know when ur turn signals, headlights and/or electric devices start acting abnormal, ur running short on power. If you have any other current hungry devices -- upgrade NOW!
    jasonwthompson, 71gold and ike72com like this.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I went all LED on all the lights (except the two front side markers), plan on going LED on the head lights. Non A/C. I think I might try it on the existing alternator and see how it goes.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Got me one of these so that the fan wont be drawing current when I am starting the car...
    CA189HJN likes this.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    There is no way my Taurus fan is gonna fit. Going to have to trim the shroud. My shroud looks so much bigger then others pictured
  10. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    BTW, here is the fan.
  11. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    ....looks way different than my fan. Are you sure it's from a V6 Taurus?
  12. stumanchu
    stumanchu Stuart
    Portland, OR
    That looks different than mine too, but it looks like you can trim enough off for pulley clearance.....at least what I see from the pics makes it look doable. My setup left me with the back of the fan motor getting into the pulley....so I trimmed just enough of the shroud perimeter on the radiator side to get clearance. Any more off of mine would put the fan blade into the radiator. It took me a few runs at it before I got it sorted out. WP_20170515_18_25_13_Pro.jpg
  13. stumanchu
    stumanchu Stuart
    Portland, OR
    Also that part of the core support where the red arrow is at the bolt, looks like it could be flattened a little for a tiny gain. I think I may have adjusted that spot forward a tiny bit with a hammer........I was scrounging for space too.
  14. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    The junk yard had it labeled as a 95. It was def a Taurus. I thought the engine was a 3.8L. Maybe it wasnt.
  15. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Looks like the 3.0l fan.
