Taurus fan
Discussion in 'General Maverick/Comet' started by smegnl, Sep 6, 2020.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Yep, looks like you are right
    Ill have to see what I can do to make it fit. I dont know the diff of low CFM between the two
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    unfortunately, it doesnt show the thickness
  3. ike72com
    ike72com Member
    Charleston SC
    Seems like those Taurus fans mostly fits vehicles they cam out of and soo few others.
    Too thick for my mustang/351w, comet/302 and f100/429.
    Wish i had checked to see if it,ll worked in f100 when i had 302 in it.
  4. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    We are gonna try, I paid almost a whole $30 for this thing....
    stumanchu, William623 and ike72com like this.
  5. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    Something I forgot to mention was that I gently massaged the rad support forward about an inch.
  6. ike72com
    ike72com Member
    Charleston SC
    You massage an inch and did not state this up front.
    Beat down award!!!!:boxing::Blasting:
    rickyracer likes this.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    well shit at this point I might as well cut the support off , extend the fenders, fill , sand repaint. Save my self some $$ on that fan....:rofl2:
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    well it fit. Little cutting here, little saws-all there...
    ike72com likes this.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I had put this on the edges, but now that I think about it, I am going to go back and pull it off. I dont want it melting all over the place. It is just reg windows foam weather stripping.
  10. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    well its in and done
    CA189HJN, Russell, stumanchu and 3 others like this.
  11. dyent
    dyent Member
    vancouver bc
    The thickness for the 3.8 on the right is 3 1/2" from mounting face to shroud edge and 4 5/8" to back of fan motor....
    David
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    The thickness on the other is "a lot less after a saws-all"
  13. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  14. 71gold
    if you do go to a controller I would suggest the Volvo relay. that way you can put the temp sensor heat range you like.
    Earl Branham and smegnl like this.
