TCP Coilover Info
Discussion in 'Technical' started by 71maverick361, Mar 23, 2016.
  1. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Micah
    Did you use the stock steering components or something else?
  2. 71Mavrk
    71Mavrk Member
    Nevada
    I just replaced it with Moog parts. I had the steering box rebuilt and I rebuilt all the power steering parts. I added the thicker Addco sway bar and the upgraded belly bar.
    If you can find the outside shock tower reinforcement plate from a later car, I would weld this in too.
    Micah
    71maverick361 likes this.
  3. 71maverick361
    Odem
    71 Grabber
    Great info Micah Inam going with mood and getting a new manual steering gear. I will check on other stuff
  4. 71maverick361
    Odem
    71 Grabber
    What is the coil over shock number your using ?
  5. 71Mavrk
    71Mavrk Member
    Nevada
    I have the Q2.
  6. 71maverick361
    Odem
    71 Grabber
    Do they have a part number on them? The sticker on the bottom of shock and do you run the 500 coils?
  7. 71Mavrk
    71Mavrk Member
    Nevada
  8. 71maverick361
    Odem
    71 Grabber
    Ok I got the 500 spring also so cool.
  9. 71maverick361
    Odem
    71 Grabber
    image.jpeg Got the TCP suspension can't wait to get to install it. Probably next month
    mavgrab302 and Crazy Larry like this.
  10. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    That's a mighty pretty thing!
  11. 71Mavrk
    71Mavrk Member
    Nevada
    They must have added to the top shock mount plate. Mine did not come with the aluminum piece.
    Micah
  12. 71maverick361
    Odem
    71 Grabber
    Yeah it's for the optional Mustang strut Brace system
    Hope that I can use plate
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Man...I'm JELLY!
  14. 71maverick361
    Odem
    71 Grabber
    Did y'all leave the shock tower covers off under the fender or reinstall them ??
  15. 71Mavrk
    71Mavrk Member
    Nevada
    Are you talking about the bolt on structural metal brace? I kind a think you want to keep those.
    Micah
