TCP Coilover Info
Discussion in 'Technical' started by 71maverick361, Mar 23, 2016.
  1. Jerry
    Jerry Member
    Woodstock, GA
    77 Maverick 2dr 302, 74 LDO
    I was also curious about the shock tower to firewall braces. The TCP site seems to imply that you don't reinstall those. Is that correct?
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You need to reinstall them.
  3. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I did not reinstall mine. No issues here. Currently running 450 lb springs up front. ride is great.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It's not a good idea. These cars are uni-body and flex a lot. Same with early Mustangs.
    Static likes this.
  5. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    You are soooo right Larry. I just reread what I was responding to... I thought we were talking about the outer shock tower pieces. (The part with the bump stop) Whoops.
    mojo and Crazy Larry like this.
  6. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    That's what was originally asked about was the plates outside the strut with bump stop on them !!
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Wow. I went back & read it and you're right. I thought he was asking about the spring tower braces.
    :slap:
  8. 71Mavrk
    71Mavrk Member
    Nevada
    I never got the impression that the instructions implied not to install them.
    I have them in and do not see a reason not to install them. I think it may help with some added rigidity to an important area that has known flex and cracking issues. I would not take the risk.
    Micah
    Crazy Larry and yellow75 like this.
  9. Jerry
    Jerry Member
    Woodstock, GA
    But you did answer my question which was about the spring tower braces.
  10. 71maverick361
    Odem
    71 Grabber
    I am going to powder coat them and reinstall them
  11. 71Mavrk
    71Mavrk Member
    Nevada
    Looks like we have two different questions in the same thread and it is making everyone confused. :coco:
    Larry already answered your question. You need to keep them. Nothing in the instructions says not to.
    Micah
  12. 71maverick361
    Odem
    71 Grabber
    Anyone have issues reinstalling front sway bar?? Seems like there isn't enough room and will hit Coil Over Shock
    Any pics of yours installed ?
