tech inspection ?
Discussion in 'Drag Racing' started by MaverickDan, Oct 28, 2010.
  1. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Yeah its a j hook guess I'll go to home depot tomorrow and get some all thread, and the autoparts store for the springs and overflow tank
  2. PaulS
    Is there any insulation on the positive wire to the solenoid?
    That looks like a fire and explosion waiting to happen.....
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Can I use electrical tape?
  4. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    I'm guessing it has a clear cover over the cable...I have one like it...I doubt it's bare wire.
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Yeah its clear insulation I thought he was talking about the cable end
  6. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Don's right about the battery. Once it moves to the trunk you are going to have to pop the trunk for the inspection. Cut off MUST be visible outside the trunk ON-OFF. Fasteners must be at least 3/8 inch. I found threaded rod with aluminum angle going across the battery works quick and easy.
    How fast do you think the old girl is going to go?
    Slicks? Drive shaft loop?
    Lug nut won’t come into play until you get a lot faster. Put a extra spring on the carb have your stock seat beats working, get a helmet just to be safe and go have fun!
    You won't have any problems with tech and if they do say something, unless your really unsafe they will let you run anyways.
    Bossmav
  7. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I have no idea fast it will go but Im hoping for a 13.4. I dont have slicks but do have a locker so do I need the drive shaft loop? Is a dot dirtbike helmet ok?
  8. ryanb
    ryanb Member
    Portland, Oregon
    '72 2D Maverick, '85 F150 Short Wide, '07 Husqvarna SMR450, 2015 Yama FZ09
    According to the 2010 NHRA Rule Book/Tech Book, helmets must be snell 2000 or SFI 41.1a minimum. I don't know how fast you have to go to be required to wear one, so if you're not required to wear one they probably won't care if it's not Snell 2000 or SFI 41.1. I don't have my rule book handy but I'm sure somebody could look up the time for you. It's general regulation 10:7 in the back.
  9. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Id bet if you have the basics covered your fine. Most tracks wont even looka at it and if they do a catch can and helmet and seatbelt will be all thats needed.
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    They way I take it is that the J-bolts on the battery are fine so long as that is stock equivilent, and the battery is still in stock location.
    I think you will have to worry in much more detail only after you move the battery to the trunk.
  11. don graham
    What track are you going to run at? Is it an NHRA or IHRA or an independent track?:)
    Okay I just read back a ways and saw Va Motorsports Park/ NHRA. 13.99 or quicker requires a helmet. I'd tell them you hope for 14's and bring any helmet with you. Don't even show it to them. Just wear it and no one will probably say a thing. Also 13.99 and utilizing slicks for a driveshaft loop. 11.49 and slower with street tires.
