temp change in 30 sec! 140 to 245!!!!
Discussion in 'Technical' started by justin has a 74, Mar 23, 2010.
  1. Bryant
    if you put the end of the gasket marked front towards the front of the motor then your fine.
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    somewhat, if you have newer (trickflow in my case) heads you have to make sure your 71 block has new steam passage holes drilled to line up exactly with the head gasket holes all within where the passage ports are...... fun times..... definately follow bryants suggestion on adjusting for your climate. I would run much less coolant when i was in the bay area than what i run now that i live in ski country ;)
