temp sensor location...
Discussion in 'Technical' started by 71gold, Aug 6, 2018.
  1. William623
    Orlando
    1973 ford maverick grabber
    Find out the thread size in the intake and then you can buy the adaptor. You can then buy it online from there, should be about $10.
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    That thing doesn't even have a distributor???? How's it run?
  3. virusmind
    virusmind Member
    STL
    Say what now?
  4. virusmind
    virusmind Member
    STL
    I ended up putting the fan switch in the thermostat housing and the temp gauge sensor where the idiot light switch used to be, on the back if the head at the firewall. We are measuring about an 8 degree difference between the two locations when the system is flowing and the thermostat is open. So basically the temp gauge reads a little low.. Good enough. Would have kinda liked to keep the idiot light.
  5. Krazy Comet
    Dismal Swamp
    Idiot lights generally come on long AFTER the problem has developed.
  6. greasemonkey
    Sedalia,MO
    The engine in the first post.
    virusmind likes this.
