Test Drive
Discussion in 'General Maverick/Comet' started by Thack, Jan 4, 2008.
  1. don graham
    tom, glad to hear that your trip was a success. Jay, if you start right now I'll catch up to you about july. :)
  2. mavmike72
    mavmike72 Member
    louisville kentucky
    nice car looks gooooooooood.....
  3. Thack
    Thack vision advicator
    Moreno Valley Ca
    Thanks for all the nice coments. I will be honest I love this car but, it scares the crap out of me. Alot of things i have done on this car are a first for me.:whew:
  4. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    do you have any engin modds?
    and if so what?
    btw that car is just so great...its honestly piece of art!
  5. Stefan
    Montreal, QC
    Thanks for posting pics of your awesome car :) Can you post some pics of the interior?
  6. Thack
    Moreno Valley Ca
    I have a couple of mods. The engine is a street boss 302, 95 302 block, 4340 crank, 4340 H beam rods, vintage boss pistons 10.5/1, plasma moly rings, Aussi cleavland heads with ferra stainless steel 2.07 1.65 valves, screw in studs guide plates, trick flow hardened push rods, crane steel billit timing set, harland sharp 1.73 roller rockers, ford racing roller lifters, Lunati roller cam 224/232 @ .050 .578/.588 lift, B&A street boss intake (will be changed next week with edelbrock e-boss), Custom equal length headers made by me 1.75 primary 3.5 collector jet hot coated, 2.5 exhaust with X pipe and 2 chamber flowmasters, Holley 650 vac secondary, stock 85 gt distributor with crane adjustable vaccum, melling HV oil pump, windage tray, custom oil pan to clear jag front suspention, weiand high flow water pump, late model serpetine belt system, and some super bitchin vintage 80's trans am valve covers.
  7. rayzorsharp
    Is that all? :jumping2:
  8. MikeG747
    MikeG747 Member
    Arkansas
    Very very nice! (y) First class all the way. :bowdown:
  9. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Thack. I can't remember - has your car been any national car magazine? If not, it's certainly deserved.
    If someone held a gun to my head and demanded that I suggest one minor change or ask me what I would differently, I'd think I'd add ground effects to the rear to match the theme of the other features (see shotty edited pic attached). Again, I don't think it's 'needed', just a thought.
    With the power that beauty is putting out, I assume you've done some changes to the drive-line?
    In my opinion, you've built a legendary Maverick that will be around looong after were all gone. :bowdown:
  10. Thack
    Moreno Valley Ca
    Nope no Magazine Jeff Kouch who did Tammy's car for Hot Rod is intrested but his current job said it was to modified ( Hemmings muscle car)
    Drive line is Fidanza aluminum flywheel, Ford Racing king cobra clutch, 91 t-5 upgraded to a 2.95 first close ratio. 2.5" steel drive shaft (couldn't fit the 3.5 aluminum drive shaft), 86 Jaguar JX6 IRS rear end with dana type 3 posi. 3.73 gears cross drilled inbaord disc and quad coil overs (the disc and coilovers are stock for this rear end).
    I'm not sure if it's legendary but, thanks for the comments.
  11. Thack
    Moreno Valley Ca
    I'm still working on the interior but here are some pictures as it sets today. I still have to recover the dash and make some trim pieces that hide the seam this trim will continue down the arm rest and cover the bolt holes. The center A/C register will have the maverick horns incorperated in the bezel wth the vents shaped to match.
  12. mavmanerick
    royal city, washington
    damn, looks like a new car inside.. how about some engine pics?
  13. mav1970
    I can understand you being somewhat humble when reading all of these great comments but don't ever sell yourself short on what you have truly accomplished building this car. What your car has does for me is stopped me from ever saying "that is good enough" when re-doing my own car. It is quality workmanship and I think that it makes me drill that hole a little straighter or sand that panel a little smoother. I apprieciate seeing all of the work that you done. :bowdown:
  14. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I am certainly looking forward to seeing Tom's car this summer! (y)
  15. Stefan
    Montreal, QC
    Can you post some details about how you made the dash?
