The allmighty 460 conversion...
Discussion in 'Technical' started by bhsboykin, Aug 18, 2005.
  1. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Oops, my bad. I just looked quick and labeled it a GM :D I just knew that as soon as I said it looked like a chubby it would turn out to be a Y block or something and make me look bad LOL. So what are you going to use ignition wise? Crank triggered coil packs or something?
  2. RabidCustoms
    you got it,this DIS will consist of a crank trigger,8 coil packs and cam sensor tied into the computer.and with any luck it will run too(y)
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I like the Mav that has a 70 Stang front subframe with a 460.
    Makes it look like it could be a stock engine compartment.
  4. Jamie Miles
    Alto, GA
    I've had a few
    I keep hearing about that, does anyone have any pics? Do the stock Mav fenders, hood and all that still bolt up right?
  5. DemoDonn49
    DemoDonn49 New Member
    Louisiana/Texas
    Where can I find the Video "Robert's Monster"? I'm considering stuffing a 425 C.I. Caddy engine/Tranny in a Maverick, and like the idea of constructing a new sub frame. Any help on getting the Video would be appreciated. Thanks, Donn
  6. ratio411
    ratio411 Member
    Pensacola
    I am not sure if it is a 'cake walk' to put all the exterior metal back, but it can't be too bad. A friend of mine has a 68 Mustang front cap on his Maverick, it looks odd as heck, but it all bolted right up. :huh:
    I need to get some pics of that car posted up... it's strange to look at!
    Dave
  7. ratio411
    ratio411 Member
    Pensacola
    That reminds me of a Pinto I saw many years ago...
    Had an Olds 455 dropped in there, shade-tree style.
    They swapped the exhaust manifolds to the opposite sides of the engine, so they exited towards the front of the car.
    Then they dropped the pipes down and looped them back from there.
    Sounds goofy, but it worked, and I wouldn't have thought of it.
    Dave
  8. stmanser
    Davenport, Iowa
    i wish i had some lots...so i could say....yeha i have one of those in my back lot...lol
  9. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    The only 390 that I know of is the FE engine. They are the same width and
    height with the exception of the High and Medium riser 427 headed versions.
    352,360 & 361,390 & 391, 406, 410, 427, 428 all have the same size block and head design. 427's are a different animal, but the block is based on the same FE design.
    460 and previous 429 are based on the 385 series blocks. More cubes, but more
    rotating weight according to Ford big block nuts.
    Seth
  10. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    If you want email me and I'll send it to you.
    mavericknutt@fordmaverick.com
  11. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
