The Edelbrock Torker 289
Discussion in 'Technical' started by sourbastard, Sep 18, 2006.
  1. don graham
    neat car. i really like that grill. should get up and go. good luck.:)
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    couldnt fit cleveland heads? wow well you found the right site we all have tight engine bays , including us windsor guys , is that photoshoped? looks pretty damn cool :yup:
  3. sourbastard
    sourbastard Member
    Australia
    1965 Ford Falcon
    It would have gotten up and gone alot better with the boss gear in it, rather unfortunate that its a bit of a squeeze to get it in.
  4. sourbastard
    sourbastard Member
    Australia
    1965 Ford Falcon
    Tight engine bays are a curse arent they!
    Yeah the colour is photoshopped on that picture, other then that nothing was changed. The original pic was of a white australian 65 Falcon, also known as the XP. They came out only with six cylinders here, most people fit v8's into them as soon as practical.
  5. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    there's nothing finer than black primer :D
    BTW, while we're on the topic, are there any differences between a torker and a twisted torker II intake? and I just looked up my cam, .498/.498 at 260 on both. I need to fire that thing up :)
  6. scooper77515
    Torker and Torker II are completely different.
    I think they made the Torker II lower profile to fit under stock hoods. It ended up being squared and boxy, where the Torker 289 is tall, and has nice straight intake passages.
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Remember when porting a T289, don't go too far with it.
    Port match the head side only about 1/4" in.
    On the plenum, they say best results come from only porting the top of the plenum. Where the carb sits, and then blended down into the tops of the ports.
    Beyond that, you are only supposed to clean up casting boogers in the bottom 2/3s of the plenum.
    This method was flow bench proven way back in the old days when this intake was 'state of the art'.
    Love that intake, best made for an SBF.
    Now the carb is a different story.
    I am a Holley guy all the way.
    Dave
  8. scooper77515
    Mine looks pretty well ported throughout. I have never seen one new, so I don't know for a fact, but you can clearly see that material has been removed from all inside surfaces.
  9. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I gasket matched and blended smooth up to 3/4" but the heavy removal was right near the gasket surface, smoothed the plenum abd removed the garbage as well as I could in the bottom of the casting, should flow some air :D
  10. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    When I had my 1970 Mav drag car, I was running a 302 with the Torker 289 intake and a Holley 600cfm double pumper. Ran great in the mid 12's.
  11. maverick75
    Thats a pretty nice falcon you got here(y)Heres the one i'm going to start working on in the next few weeks:bouncy:
  12. scooper77515
    Where... :huh:
  13. eddie1975
    Martinsburg, WV
    sold
    i dont see anything either , execpt for those 3 Xs
  14. scooper77515
    I don't get the Xs with Firefox. Just blank space.
    Click on his website. Same thing, just blank space.
    Hey, M-75, you got a problem with your pictures? Anything we can do to help?
  15. sourbastard
    sourbastard Member
    Australia
    1965 Ford Falcon
    Apart from the Info on Fletchs mustang page is there any other info or guides on porting the T289?
    Thanks for your comments guys, really appreciated.
