The Green Hornet Maverick build...
Discussion in 'Maverick/Comet Projects' started by maverickn, Sep 15, 2013.
  1. Craig Selvey
    ......and the brakes. Plenty of places to spend money. :D
  2. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
  3. maverickn
    maverickn Member
    Arkansas
    1972 Ford Maverick
    I never saw how it sat with the motor. This one I got with the motor pulled. It seems to sit high though compared to the 72. Thanks for the link to the suspension/steering. I plan on doing everything eventually..I just wanted to know what would be a whole lot easier with the motor out to go ahead and tackle.
  4. maverickn
    maverickn Member
    Arkansas
    1972 Ford Maverick
    Started doing some initial sanding since I don't have much else to do for awhile on it.
    Found some bondo I didn't know was there :-(
    This was underneath. Not too bad...
    Got some rusty mess on the front of the hood. What is the best method of fixing stuff like this.
  5. maverickn
    maverickn Member
    Arkansas
    1972 Ford Maverick
    Also..for a feller on a budget who doesn't already have a nice air compressor setup.
    What's the best tools to sand a car? I don't care to spend a few hundred on tools..but dost know that I can easily afford a compressor setup.
    I've got an electric orbital sander and a grinder.. please advise
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Sanding lacquer is a b####. You're better off having it media-blasted or using paint stripper. Either way is messy, but far more effective, and sandpaper is expensive.
  7. maverickn
    maverickn Member
    Arkansas
    1972 Ford Maverick
    What kind of paint stripper is recommended?
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Aircraft Remover (brand).
    Make sure you follow all instructions (especially pertaining to safety).
  9. maverickn
    maverickn Member
    Arkansas
    1972 Ford Maverick
    Haha I'll try. I'm not good with directions! Thanks for the info.
  10. kboldin
    Santee, CA.
    Not that I'm a pro or anything but I've found that if you score/scratch (rough up) the area to be stripped the aircraft remover or kleen strip works better. I've used both on wheels, body panels etc...
  11. maverickn
    maverickn Member
    Arkansas
    1972 Ford Maverick
    Thanks for the tip kboldin. After I finish stripping the paint off with my wire cup I will be going to purchase some aircraft stripper.
