The Official WOOOOOOO Project - 1970 Maverick Repore
Discussion in 'Maverick/Comet Projects' started by satchelmcqueen, Sep 7, 2017.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
  2. mavgrab302
    Maybe consider a new set of Dynacorn hinges. Hood looks great...
  3. satchelmcqueen
    north georgia
    It will come alive very soon. Muuuhahahahahaa!
    mavgrab302, palser64 and Crazy Larry like this.
  4. satchelmcqueen
    north georgia
    Got the 302 freshened up and some repaint going.
    Crazy Larry likes this.
  5. satchelmcqueen
    north georgia
    More videos to come as soon as I have time to edit. Until then...here's a few update pics.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Making progress. :thumbs2:
    satchelmcqueen likes this.
  7. satchelmcqueen
    north georgia
    well crap. i bought NEW intake bolts from summit and just snapped one off in the head. the last pull on a 25ftlb bolt and it snapped. im debating on whether to see if it leaks or just go ahead and redo it. i thought it felt mushy around 20lbs but i never thought a bolt at 25 would break from summit. now i know why people use apr. its a middle bolt so im hoping the pressure from the rest of the good bolts holds it and i used a paper thin layer of red rvt as always on an intake.
    its an edelbrock performer.
    thoughts??
    i was THAT CLOSE TO BEING PERFECT! arrrgrgggg!!
  8. satchelmcqueen
    north georgia
    Got it done. Heres a good look at the "almost" final set up. This thing is awesome!
  9. Hotrock
    Munroe Falls, Ohio
    Now is the time to replace that intake bolt not when the engine is in the car. Even if the intake does not leak I guarantee you are going to lose some sleep thinking about that broken off manifold bolt you left on your engine. Others may not notice the broken bolt but you know it is there waiting for you to correct the mistake!
    A Performer RPM intake would have been a better choice than the Performer. The Performer isn't much better than the stock intake, just a little less weight.
  10. satchelmcqueen
    north georgia
    Yep. Already pulled it back off. Its eating at me so I'm just going to redo it. Bolt didnt actually break but the thread popped and was at its limit. All came out easy. Just gotta clean up and do it after work today.
  11. Hotrock
    Munroe Falls, Ohio
    Right on!!!!!
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The Performer is gonna run fine. I had a Performer. I replaced it with a Performer RPM and noticed no difference in power. Unless you're turning 6000+ RPM, you're not gonna need a Performer RPM.
  13. satchelmcqueen
    north georgia
    Yes it will and has. This is what I replaced the stock manifold with 22yrs ago. I just cleaned it up and painted it. A very low budget engine swap is all I'm doing until I can get what I really want in a few years.
    The neat thing is, ill get to see how this exact engine set up pulls in the 2500lb maverick vs a 3800 lb 70 f100. This will be fun.
  14. satchelmcqueen
    north georgia
    Episode 19!
  15. satchelmcqueen
    north georgia
    Episode 20!
