The true cost of cheap gauges
Discussion in 'Technical' started by facelessnumber, Aug 16, 2009.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    I THINK I BOUGHT THE SAME GAUGES AS YOU ! is it 3 small ones i think they wer 20$ and my water temp gauge dosent work some times and the lights wer very dim then they started to burn out one by one ! look at my pics to see if they are the same one's there should be a rule's about building crap
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    If it was this set, then yes.
    The ammeter seems to be accurate enough, I checked that with my multimeter. I don't have a way to check the oil pressure gauge, but what it's telling me seems sane. The temp gauge is junk though. All of them will be replaced soon.
  3. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    stewart warner makes good guages as well they have been around a long time.
  4. darren
    there should be a rule's about building crap[/QUOTE]
    That would be the end of the big box stores and Walmart. :thumbs2:
  5. mercgt73
    mercgt73 Member
    This eBay store is selling Stewart Warner gauges cheap to clear out old stock. Might be a deal or two in there.
    DD Instruments
  6. Mavaholic
    There is. You get what you pay for. :D
  7. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    At 103.00 you got off cheap it could have cost you a lot MORE like the cost of a motor replacement .
  8. facelessnumber
    Memphis, TN
    '71 Grabber
    Yes... I am thankful that the gauge wasn't erring in the other direction.
  9. 302-72-mav
    302-72-mav Member
    sactown CA
    i bought the other one's but i seen that set up there :16suspect
  10. Octavio
    Octavio Member
    Chihuahua, Mexico
    1977 4 door automatic
    excuse me; how may I install the amp meter???; my battery is being depleted very fast
    thanks in advance
    Octavio
  11. mav1970
    Isn't everything in Harbor Freight made in China? If China had rules against building crap nothing would be built in China :cry:
  12. darren
    Doing it for a living I dont trust any in car gauge. Have to verify with a known good thermometer or IR. A good IR gun should be in a car guys garage. It has so many uses. I highly suggest it. When I run a car I have my thermometer in the rad and I use my IR gun to monitor the temp below the stat If I am burping out air. When the sat opens and it burps I top it off and seal it. Then use the IR gun to verify fan on temp.
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    +1
  14. Dave B
    He said that in 2009!!! :yup:
  15. 71gold
    and they are still in business today...:tiphat:
