Thermostat housing leaking .... again.
Discussion in 'Technical' started by mashori, May 15, 2011.
  1. rthomas771
    It works every time.
    [​IMG] [​IMG]
    I perfer Permatex #2. I seen too many people make a mess using RTV and still have a leak. This is were more is not better when RTV is inside the oil pan or radiator.
  2. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    here's a pic of the rubber band/pencil trick. I used the permatex silicone made for water pump/thermastat housing.
  3. baddad457
    I guess you missed the part where I said "a thin film" :D
  4. rthomas771
    ... And you missed the part where I said "many people" :D
    Don't get me wrong, I will use RTV sometimes like the corners on the (4-piece) oil pan gasket or on the crankshalf seal in the timing cover. Any other time its Permatex #2
  5. blugene
  6. maverick75
    someone doesn't read :D
  7. PaulS
    "Ultra Blue" is silicone rtv - when sealing a flange it is best to start with flat clean surfaces and if a sealer is desired then use a flange sealer - like Loc-tite 518. It is an anaerobic flange sealer. It won't cure until you tighten it down and as it cures it expands to fill voids up to .050". A thin film (.010") on each side of the gasket and you will be wiping it off the outside - so use it sparingly. It peals off with the gasket when you need to remove it and leaves a clean ready to use surface behind.
  8. Dave B
    Yes, I like 518, it's good stuff (5188 is even stronger). One of the wholesalers I buy bearings at, has a huge Loctite display, I'm always buying something.
  9. justin has a 74
    kentucky
    :cry:
    :badwords:
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So . . . thanks to everyone for the info, here is what I did today.
    The housing was actually slightly uneven, I filed it down straight, I'm sure that will make a HUGE difference. Got the loctite 518 and for some reason the last gasket I ordered wasn't very well fitting, got a felpro, MUCH better fit. Didn't take any pics . . . shame on me. I haven't installed them yet, that will happen tomorrow.
  11. injectedmav
    injectedmav Member
    Georgia
    I use a stock type paper gasket with a very thin film of Motorcraft TA-30 on both sides. I've never had one leak.
    Just for info, the TA-30 is particularly well suited for cooling systems as it is RTV silicone that actually cures in the presence of moisture. A little goes a long way and I still use the gaskets. The only gaskets I replace with that stuff is the end gaskets on the 5.0L/302 intake manifolds. All the paper ones I use a thin film to fill pores and supplement the adhesion to the metal surfaces.
  12. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I use permatex ultra grey on both side of the gasket and haven't had a leak yet. Comes off pretty easy too.
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Put the ultra black on, gasket went on over the thermostat and let that dry overnight. Then installed the thermostat housing after putting more ultra black on the intake side. Put the bolts on and let it sit over night and will go back to it tomorrow.
    Unfortunately I think I may have overtightened the passenger side bolt, on the last turn felt it get really tight and then a little loose, so I may have cross threaded that bolt thread. If there is a leak will need to tap that hole . . . arggg.
  14. 71gold
    that may cause a leak...:yup:
    letting it dry before pulling it down tight will leave...air pockets... in the sealant...
  15. baddad457
    Ditto, I never let something dry overnight with RTV then bolt it on. Gotta be gentle with aluminum threads too. You can't crank bolts down like you can with steel or iron threads.
