Thermostat Housing
Discussion in 'General Maverick/Comet' started by Tannersg1, Aug 31, 2014.
  1. Tannersg1
    Tannersg1 Member
    Classified
    What works best for installing the thermostat housing on a 302? I'm looking for sealant, gasket suggestions! Yes mine leaks after swapping out my intake before I even started it!!!
  2. rthomas771
    I use Permatex #2...not a big fan of the RTV any color.
  3. 71gold
    make sure the gasket and T-stat are seated...:yup:
  4. mojo
    I use regular gasket cement on t-stat and water pumps. Old school - I guess. Has worked for me, over many years.
  5. Tannersg1
    Tannersg1 Member
    Classified
    So i should use Permatex 2 on both sides of the gasket?
  6. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    The thing I've found to work the best is the Mr. Gasket O ring that sits inside the thermostat housing. As long as you seat it right it and tighten it enough it will seal and not leak. No rtv, no sealant required.
  7. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    .......X2
  8. 70maverick302
    70maverick302 Member
    70 Ford Maverick
    The peal and stick style thermostat gaskets make the install easier on a ford(vertical thermostat orientation).
  9. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    Make sure that the surfaces are flat. I have used Permatex #2 for fifty years. Good stuff.
  10. Hairy W Bush
    Hairy W Bush Member
    Palm Coast, Fl
    1972 Maverick Grabber
    I've used the permatex high tack gasket sealent and never had an issue. I used that #2 crap on an intake gasket and it never cured and leaked.
