Things might be wrong if…
Discussion in 'Technical' started by njnjtek, Feb 26, 2004.
  1. riporter
    riporter Member
    Charleston S.C.
    Without the gauge for a reference point you can't set the timing with a timing light to factory specs...that gauge cost is about 5 bucks at a performance shop. The white mark on the harmonic balancer shoud be 6 degrees below top dead center and should be set with all vacuum advance hoses pulled and capped.
    Your idle should be set at 850 rpm with the car in park and 550 with the car in gear and you foot on the brake...assuming its a Auto tranny.
    These are factory specs for a stock 72, 302 2V with auto tranny.
    Hope it helps:)
  2. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    I’ve been driving short distances only…
    after an oil change I did notice a very small amount of white and mocha brown substance… I think I have to take it on a longer trip to burn the carbon out of it… maybe it will get rid of the condensation in my oil too
  3. Hanible
    Hanible Member
    outa my mind in Shelby Nebraska
    69.5 2 door Maverick 170 I6
    while on the subject of carbeators does any one know what the fuel air screqw should be set at for a Carter 1 bbl on a 200 I6
    please... ... ...
    anyone... ... ... ...
    If so THanx... ... ... ...
  4. Craig Selvey
    Somewhere less than 1 1/2 turns out from dead bottom. Screw it all the way down (not tight, just all the way down). Back it out less than 1 1/2 turns. Have car running when doing this and adjust for smooth operation.
  5. Hanible
    Hanible Member
    tried that ounce but didn't work the car ran like crap
    could it be the fact that i aint got the tube from the manifol to the air cleaner
    all advice welcomed
    thanx
