Throttle cable help!!!
Discussion in 'Technical' started by maverick93, Jun 12, 2013.
  1. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    okay, so I have a 70 maverick which now has a 302 in it, pretty much looking for a v8 throttle cable! would I just need to buy a gas pedal with the later style end on it and a lokar cable or what!? and if so where can I get the lokar cable for these cars? thanks
  2. Del Austin
    Del Austin Member
    Chandler, AZ
    1970 Maverick & 1974 Maverick
    If you use the Lokar cable you will need to fabricate a piece to attach the cable to the stock pedal assembly or use the adapter from the Mr. Gaskets cable kit. I would recommend the Mr. Gasket cable, but it is not near the quality of the Lokar unit.
  3. Dave B
    I used the stock retainer, on my Lokar cable, works fine.
  4. Joe Dirt
    i sell a kit for holley 4brl in a maverick but you need the later style pedal
  5. bmcdaniel
    bmcdaniel Senile Member
    Lokar cable here, bolted right up to my stock pedal and clip.
  6. Del Austin
    Del Austin Member
    Chandler, AZ
    Used a 74 pedal assembly in my 70. Maybe that is why I needed the adapter. Either way you can't beat the Lokar cable for quality.
  7. junrai
    junrai Member
    rancho cordova ca
    lokar bolted right up to my 72 comet 302 edelbrock aftermarket carb but stock pedals
    I bought mine at a local speed shop called tognottiesautoworld Im sure you can find them online.
    I just read the package and it said universal so I went with it and it was a breeze to install. it might have taken me all of 10 minutes :thumbs2: very nice looking unit also. it bolts to the corner of your carb and is already correctly spaced to line up with the linkage :clap:
    best $35 I ever spent :bowdown:
  8. 71gold
    Lokar cable ...:thumbs2:
  9. mav man
    mav man Member
    wi
    70mav
    summit racing should have them
  10. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    okay, thanks guys, one more question, is it a maverick specific cable, or fits most pedals that I should get?
  11. Dave B
    It's a universal kit. TC1000U
