Throttle Cable
Discussion in 'Technical' started by Racer_X, Apr 30, 2015.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    So far I have had no luck with aftermarket throttle cables, I need a suggestion on what aftermarket cable works best, post part numbers if you have them too. I have been thinking about trying one from lokar but their shortest one is 4 inches longer than stock.
  2. 71gold
    lokar...can be cut to size...been there and done that...:thumbs2:
    Racer_X likes this.
  3. Racer_X
    North Carolina
    did you have any problems with it breaking?
  4. Hotrock
    Munroe Falls, Ohio
    I've been running a Lokar for over 10 years and as 71gold says, it can be cut to the needed length.
  5. Racer_X
    North Carolina
    thanks guys, everything else I have tried has been junk.
  6. Trojan
    Trojan Member
    Bakersfield California
    1972 Mercury Comet
    Been there. You can buy the spectre POS kit sold at autozo**/pepfellows/oreally but you have to buy 2 of them to make one bulletproof version. The little "ball" at one end of the braided cable always snaps so just cut it and use the screw clamped bits from both kits on both ends of the braided cable. Should cost you 60 for both kits plus maybe 20-30 for a bracket if you don't decide to make your own. If you're interested I can post pictures of mine later on.
  7. Racer_X
    North Carolina
    I ended up getting the lokar, its works great
  8. Hotrock
    Munroe Falls, Ohio
    Can you provide the Lokar throttle cable part number and any modification you needed to make for other members on the site?
  9. 71gold
    cable and bracket I used...:thumbs2:
    Lokar SRK-4000 - Lokar Throttle Cable Bracket
    Summit Racing Part Number:LOK-TC-1000U
  10. Racer_X
    North Carolina
    I really didn't do anything special, just cut it to length, when you put it through the fire wall use washers.
