Throttle cable
Discussion in 'General Maverick/Comet' started by Tannersg1, Mar 19, 2014.
  1. Tannersg1
    Tannersg1 Member
    Classified
    So you have no issues with the cable dragging on the cable housing when you operate the pedal? Which pedal are you using? Is it the pedal with a clevis or the later model one with the nylon bushing in it?
  2. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    No issues at all. I'm using the early pedal for a 71
  3. Tannersg1
    Tannersg1 Member
    Classified
    How did you attach the cable to the pedal?
  4. 7D2 Grabber
    7D2 Grabber Member
    I used the factory plastic tab
  5. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i also took the dual screw mount off the old cable and used it as a bracket for my lokar throttle cable. worked like a charm.
  6. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Lokar is the only way to go tranny or throttle cable
