throwing belts and need help????
Discussion in 'Technical' started by 73'goose, Apr 8, 2007.
  1. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    It feels really good the first time you cross it too! (y) I actually ran 101 at 14.03 before I finally got into the 13's. Good luck!
  2. stmanser
    Davenport, Iowa
    is there a guide out there.. saying if you have this et...y uo should have this mph.. or vice versa?
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I always just use the performance calculator on hardcore50.com its as close as anything I have seen, but just like most guidlines, its perfect "set-up" senerio. and it will give a disclaimer of +- 5%.
  4. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Something is flexing if you have everything lined up. No way a bigger pulley with a deeper groove should throw a belt if it's all lined up. Make sure all your accessory bolts are in and tight.
  5. stmanser
    Davenport, Iowa
    Enter your car's weight and horsepower
    Weight:2820
    HP:192
    1/4 mile ET:14.25
    1/4 mile MPH:95.64
    1/8 mile ET:9.0
    1/8 mile MPH:77.25
    that is as close as it can get
    actual numbers are
    14.220
    96.92 mph
  6. stmanser
    Davenport, Iowa
    the only other thing i can think of, is the belt is shaking/vibrating/so much that it is actually coming off itself.
    have you tried overly tightening it?
  7. PaulS
    There is a formula that will tell you how quickly you can get through a quarter mile with a given HP. You could work it around to figure How much HP you have with a given time.
    The problem with math is that there are a lot of variables that have "normal" values plugged in so they are never exact. Also if you have less traction your times will be slower. That will tell you that you have less HP than you really do. The best way to find out how much HP you have is an engine Dyno and the best way to get your times is to run down the strip.
