Time for Drag Slicks-
Discussion in 'Drag Racing' started by chrisb, Mar 20, 2011.
  1. ryanb
    ryanb Member
    Portland, Oregon
    '72 2D Maverick, '85 F150 Short Wide, '07 Husqvarna SMR450, 2015 Yama FZ09
    I had difficulty finding a full spool, and we wanted to build our rear end on the cheap side of things because eventually we will be building a 9" and swapping out the 8" we're building now. But I'm not planning on doing that until way down the road.
  2. Recrdholdr
    Recrdholdr National Record Holder
    London Ontario
    I want a 70-73 Maverick
    In reality the spool will take care of most of the spinning issues. It's easy to spin one tire not so easy to spin both.
  3. Rocket!
    Rocket! Member
    Philadelphia
    1971 maverick grabber
    oh sorry thought you already had a 9 inch in there. don't waste any money on the 8in rear expecally if you are going to put a 9in in there. leave it the way it is for now untill you get the 9in done then that money you were going to put in the 8in you can put somewhere else in the car towards a set of heads or something
  4. ryanb
    ryanb Member
    Portland, Oregon
    Cash is tight, what little money we do have for a rearend wouldn't be enough to get a 9", rebuild it, buy gears and a full spool, and for the amount of HP and torque we're making an 8" shouldn't have any problem handling it. We already bought the gears and mini spool for the 8" so unfortunately it's a little late to try and build a 9". Later down the road (several years) when we're making more power we will look into a 9.
