Timing Covers
Discussion in 'General Maverick/Comet' started by Eddie Maverick, Jan 16, 2008.
  1. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I have a question about timing covers. (two part question)
    I have a 68 block that i recently rebuilt, and before I did I idiotically (sp) broke the timing cover. So I went to the JY and pulled a nice one off a 90's bronco.
    My questions are:
    1. Can I use that cover with a standart rotation water pump, provided the cover will bout up to my engine?
    2. Can I use the nifty double roller timing gears that I pulled from that bronco as well?
    Thanks
  2. yellow75
    Tillamook Oregon
    Ed not really up to speed on the Bronco 302 but does it have the dip stick tube in the timing cover and does it have a place for fuel pump to bolt on. I have done the opposite and bolted old style timing cover to newer block so it will bolt on and water pump rotation is not an issue, my guess is the timing chain will not work though something to do with thickness of cam gear. I am sure some of the pros will chime in on this one soon.
  3. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
  4. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I drilled out the dipstick in this one. I was not meant for it, but did have to boss on the cover to drill through. Also the fuel pump eccentric is not there, which is cool since i'm gonna run and electric fuel pump.
    I hope the timing gears will work though, they do fit on the cam and crank.
    I read on Ford Muscle that as long as I get the correct std, rotation water pump everything will work and not leak.
    but I'm still out to jury
  5. Mavman72
    Arent those 90s' broncos roller motors??? if so the gears wont work without the thrust plate from the roller motor.If it isnt a roller motor(bronco) you should be golden as long as the chain isnt worn out.
  6. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    i plan on buyin a new chain, and I pulled the thrust plate off that engine too. And it was an f-150 not a bronco, my mistake.
    so all good??
  7. Mavman72
    Should be,but I am not sure about the roller motor thing.I think some were and some we not.
  8. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    If your buying a new chain, they come with gears so dont worry about using used stuff.
  9. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I was buying just a chain, Autozone has the replacement chain for 11.99
    If using the double roller set from the F-150, if it was not going to work wouldn;t I notice something?
    Like it not fitting, rubbing, etc... will there be some sort of visual or physical indication?
    Thanks guys
  10. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    The chain will work just fine , I`ve been running the same timing chain for years with no problems. The only bad thing is I think the factory dual roller timming chain sets the cam timming back 4* vs an aftermarket timing chain set ?
  11. Andysutt
    Conway Arkansas
    1972 Comet GT
    You can get a 3 keyway double roller timing chain for around $25 bucks IIRC and you can adjust your cam accordingly with it.
    Advance Auto Part Number: 9163 Clevite Double Roller timing chain 23.99
    This part is listed for a 95 F-150 with a 302 and a 73 Ford Maverick with a 302
    So either cover you have should work.
