Timing jumping
Discussion in 'Technical' started by adam 72, Sep 28, 2020.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    That looks like a factory type chain, and it is not a dual roller. If you have tried multiple distributors and the problem persisted, it is not a sheared pin, unless the oil pump is dragging enough to shear the pin of every distributor you put in it. So if the timing chain was indexed and installed correctly, the distributor(s) indexed and installed correctly without a sheared pin, then your problem is elsewhere, such as your firing order, coil, condensor, points, plugs, wires, cap, rotor, ignition module, ect.. Align the timing mark on the damper to the timing indicator and ensure the rotor is pointing to #1 cylinder on the distributor cap. Once that is done and the distributor is locked down, it should keep that orientation whether or not it starts. If after repeatedly cranking/running the engine the rotor orientation changes it is either the pin or chain. The chain can fail either by jumping a cog on the cam or crank gear, or the cam gear slipping, or the crank gear slipping. The gears slipping is very unlikely unless they were installed without the crank key or cam pin. If the chain is jumping and it jumps enough you can get bent valves and/or pushrods.
    mojo likes this.
  2. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    My plan
    1) check distributor pin
    2) coil was new, but will check resistances
    3) verify firing order
    4) verify TDC on compression stroke and check where the rotor is pointing
    Maybe ill upgrade the distributor aasuming its not thr problem. Any recommendation?
  3. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    You’re going on the assumption that the “mystery mechanic” did everything correctly.
    IMHO it’s time to remove the front cover and check the cam, timing gears, chain and ALL associated parts.
    ike72com and jasonwthompson like this.
  4. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    My plan
    3) verify firing ordee
    5) then rip into everything
  5. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    And i guess if i twar into its time to uogeade everything i can. Anything I should start looming at getting or measure?
    This will be my first time doing this
  6. ike72com
    ike72com Member
    Charleston SC
  7. ike72com
    ike72com Member
    Charleston SC
    I,d suggest getting help from rebuilder. You did say motor is recently rebuilt.
  8. ike72com
    ike72com Member
    Charleston SC
  9. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Good news! Got the car back in my life... Did all the damage control, got rid of rodent nest's and all.
    Soaked the cylinders in mystery oil and freed them up and it rotates now.
    Bad news.... Coolant in the oil pan when it went to change oil.... Any other options to look at before pulling the head?
    Thanks
  10. jasonwthompson
    Carrollton TX
    Coolant in the pan can be, at best head gasket, at worst cracked head or block.
  11. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Yeah I pulled the head. I dont see any obvious cracks in either. The gasket was a classic inlines metal gasket that sat there for about 7 years. Woulsnt be surpirses if it rusted through
  12. ike72com
    ike72com Member
    Charleston SC
    Inspect gasket and heads. Should be some tailtale sign if failed. Take pic and post if u need help.
  13. ike72com
    ike72com Member
    Charleston SC
    Well!!!! My streak ended. Last week my timing jumped in f100 with 429.
    adam 72 likes this.
  14. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Cracks can be very, very hard to see, impossible basically unless you have a machine shop magnaflux the part.
  15. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    So pulled the head... It rotates by hand now but this concerns me. Soaked it in mystery oil for a day or two
