Timing jumping
Discussion in 'Technical' started by adam 72, Sep 28, 2020.
  1. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Think it rusted through or wasnt flush
  2. ike72com
    ike72com Member
    Charleston SC
    Stop!!!!
    Have a seat and crack open a cold beer.
  3. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Already did that, dont you worry
    ike72com likes this.
  4. Krazy Comet
    Was engine stored with water in block? Lowest likely temp encountered?
  5. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Northern NM in the mountains for the last 4 years. So maybe around 0 degrees
  6. Krazy Comet
    Was there water in block?
  7. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    There shouldnt have been. My radiator was empty so im guessing that was the source. Antifreeze came out my oil.pan
  8. ike72com
    ike72com Member
    Charleston SC
    Are you sure u got a rebuilt motor? or a repainted used motor?
    Mechanic possibly forgot or too lazy to torque heads is my assumption.
  9. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    We torqued the heads down with a torques wench, but the wench could have been out of spec. The motor looked clean through and through and bored .040 with fresh cylinder walls.
  10. ike72com
    ike72com Member
    Charleston SC
    Do over, it,ll turn out better next time. Been there! And don,t let motor sit so long unfinished. But you already knew that.:)
  11. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    It was a victim of circumstances. My cousin was helping build it, then went missing. Long story short, it didnt turn out well and it was discouraged from getting the car back.
  12. Krazy Comet
    Fresh antifreeze contains a rust inhibitor, even if gasket did leak it should not have rusted.
  13. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Well water got in somehow then. This is where its at and now its time to deal with it. Since its pitted I assume i would have to bore the cylinders? Since its already .040 ovee is there much left to bore?
    I have the chance to get a 200 ready to go with dual outler headers and a triple carb offenhouser(?) Intake.
  14. 71gold
    I vote...no on 200.
  15. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Why is that? I have no issues with the 6
