Timing marks on stock 302
Discussion in 'Technical' started by Maverick Dude, Aug 11, 2022.
  1. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Here is a photo showing what I believe is the stock timing pointer for the original damper. I circled it in the photo. Can anyone tell me what to expect on the damper? Does the stock one typically just have a single line, or a few marks. I plan to clean it up this weekend to check. Thanks.
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    The stock one usually isn't where it used to be. But had a grid and will probably have to be cleaned well to read it.
    Maverick Dude likes this.
  3. 71gold
    to start with I just bring number 1 piston to compression TDC and see what it's lining up with.
    if it's the original damper the outer ring may have slipped.
  4. Maverick Dude
    I rigged up my remote starter to the car. The clips were small so I placed a clamp from a set of jumper cables on the positive side of the battery and clipped onto the clamp. I placed the other clip on the “S” side of the starter solenoid. Pictures shown. After testing the start button I was able to crawl under the car front of the car which was sitting on ramps. I saw no marks on the harmonic balancer, but after one hit on the start button, the timing marks came into view. I ordered a piston stop and plan to use it to help find TDC. ( turning the engine with a bar and a socket).
    DA79764C-C913-45DA-8AA7-1540D85A0AB7.jpeg 69010EED-5882-4599-8EA7-9516D7ECAEFF.jpeg B3D01998-8750-436D-941D-42713F3984DE.jpeg 3CCED880-5302-4555-94A9-67A9B1289CE7.jpeg
  5. Maverick Dude
    After bumping the starter button the timing marks showed up. The shot was taken from underneath the car looking upward. I could see all the marks clearly.
    5A7DE0FF-F4BE-41D8-8120-5B35803B3877.jpeg 73B7E6A8-D871-41AF-8079-B99F8D4E9112.jpeg
  6. Maverick Dude
    8F834C4B-A66C-4756-B173-47678DB28C6E.png I ordered a piston stop from Amazon. Should be here soon.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I rotated mine like Atlas and I could not find any marks.
  8. Krazy Comet
    If it has a timing pointer, marks are/were on damper(at least from factory).
    I've never seen a 221, 260, 289, 302 or 351W engine that didn't have a marked balancer.
  9. greasemonkey
    Sedalia,MO
    True dat! It has marks.
  10. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    well then I need to have my SO come look. She normally finds all the other things I swear are missing........
  11. Maverick Dude
    I tried to time the engine but there was such a small gap to view the pointer that I painted a wider line at 6 degrees BTDC and tried it again. I loosened the hold down and reset the timing for 6 degrees BTDC. I could make out the thicker white line this time. The idle increased and it smoothed out. I believe the timing was less than this when I started. I’ll drive it at this setting for a while then try advance it a bit more.
