Tire range for 8 inch rims.
Discussion in 'Technical' started by Maverick Dude, May 20, 2020.
  1. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I have a set of used Yokohama H rated P205 60 R15 tires. I noticed in the tire and rim section that a common rim for a rear tire on Mavericks is an 8 inch with a 3.5 to 4.25 inch rear back spacing. I also noticed that an 8 inch rim is pretty much as wide as you want to go with 205 60 R15 tires. I was thinking of choosing 7 inch rims for the front and 8 inch rims for the back and using my P205 60 R15 tires on all for corners with a plan to purchase 275 60 R 15’s for the rears, down the line. Think this would work? Thanks.
    5511212B-A46E-40AA-86C9-1E5A239DDD3D.jpeg A2C829A2-8020-454C-B15B-4BE29D8972A1.jpeg
  2. dyent
    dyent Member
    vancouver bc
    Maverick Dude likes this.
  3. Maverick Dude
    Thanks David. Since the 205’s are a given, it seems they recommend the 7 inch rim being the maximum width, so that works for the front but not for 8 inch rear rims. So if I stayed with 7 inch rims on all four corners the site recommends a maximum with of 255 mm if I buy a set of rears later on; still not bad but not as cool as 275 mm. From from a practical stand point what is the maximum width for rear tires on a Maverick without any fender rolling or any other mods? Thanks guys.
  4. 71gold
    these on 15"X 8" rims...no lip roll.
  5. TeeEl
    TeeEl New Old Member
    Colorado
    '73 Ford Maverick
    The tire size for a given rim-width is pretty much dictated by the tire's aspect ratio. You can put a 235-60 on a 7-inch rim, but a 235-45 requires at least a 8-inch rim. You can put a 265-60 on a 8-inch rim, but a 265-45 needs at least a 9-inch rim...
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I very recently replaced the front rims with 7 inch diameter and 4 inch backspace. The fronts are 235/60 15, they do not rub and required no modification. The rears are 255/60 15 and fit without problem.
  7. TeeEl
    Colorado
    '73 Ford Maverick
    8-inch diameter?? ...
  8. jasonwthompson
    Carrollton TX
    No, sorry. 7 inch diameter.
  9. TeeEl
    Colorado
    '73 Ford Maverick
    7 inch diameter???!
  10. Maverick Dude
    I think we’re talking width, not diameter.:yup:
    TeeEl and 71gold like this.
