tire size
Discussion in 'General Maverick/Comet' started by Scotty P, Oct 26, 2003.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    rear
    Looks sweet!! I am running a "slightly" narrower rear also. Frustrating thing, the tires only rub during turns. So I have body roll somewhere I am convinced these will work. (is that because they are non returnable?!) Hammered the throttle today and hooked for the first time in a looooong time. Felt too good to give up on this problem.. Scott
  2. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    What is the exact size and backspace of the wheels?
  3. Scotty P
    Scotty P Member
    santa rosa, ca
    size
    15 x 8.5 w/4 7/8 b.s. rides fine as long as I don't turn!!!! Scott
    Old Guy suggested I check the shackle bushings. Not sure how to do that other than visual, they are plenty of cracks on the rubbers as it is original. Would that cause the car to roll into turns? Shocks only control up/down in a stright line, yes? I am a suspension idiot! Scott
  4. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I'm running a set of 295/50-15 tires mounted on 8" rims with a 4" backspace and have no troubles at all with clearance or rubbing....of course I did two mods to help out. I rolled the rear fender lips and removed the mid stock spring and replaced it with a heavier duty spring which raised the rear not quite half and inch and gave it a much more stable ride in the corners as well helping the tires keep their distance. It also looks way cool!
  5. M.A.V.
    Macon,Georgia
    If the tires are rubbing only on the inner fender well you could just "contour " them slightly with a Hammer.
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    Hammer!
    I removed 100% of the inner lip, about 7/8" wide. Any hammering now will change the outside shape. I am not anxious to tackle that one. Maybe the body shop is the only hope. Although, I do not think it should roll that much.. Scott
  7. Scotty P
    Scotty P Member
    santa rosa, ca
    Grabber
    With that size tire it must be outside the fender. I wanted to stay tucked under, almost trying for a slight tubbed look.295 is a LOT of tire! 50's are also shoretr Mine are a full 28" tall
  8. M.A.V.
    Macon,Georgia
    I thought you meant that the tire was rubbing on the inside fender well (closest to the trunk) thats what I was talking about using the hammer on.;)
  9. Scotty P
    Scotty P Member
    santa rosa, ca
    sorry
    The inner of the outter! Scott
  10. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Add mine to the list of Green Mav's with big and littles.
  11. M.A.V.
    Macon,Georgia
    Sweet lookin ride Russ!:cool:
  12. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    p.m. sent, Scotty.
  13. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    that is a nice pic of yours russ, hey when did your boat grow into the camping trailer? :D :bananaman :bananaman
  14. Scotty P
    Scotty P Member
    santa rosa, ca
    Thanks all
    After further research I agree that my springs are shot! Hmm, 33 years old, Nitrous, slicks etc... Can't imagine why! I ordered new 4 leafs from Springs-n-Things with poly inserts. Should help out a LOT! I am also replacing the brand new GR2 shocks wih sometong a bit stiffer. Thanks for all the help! Scott
  15. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I like the contrast...
    ....between large rears and narrow fronts.
    What size tires and wheels are the fronts?
    Seth
