Tire Sizes???
Discussion in 'Wheels and Tires' started by Slider28, Oct 5, 2007.
  1. MBD
    MBD New Member
    Georgia
    Are your tires rubbing on the outside at all?
    Also, how much space do you have on the inside before the tires would rub on the leaf spring?
    MD
  2. mavmike72
    mavmike72 Member
    louisville kentucky
    i have about 3/8 on the inside away from the leaf.
    and about 1 1/2 from wheel well.
  3. rayzorsharp
    Have you ever tried a 275/60 in there? Seems like a lot of room still left.
  4. mavmike72
    mavmike72 Member
    louisville kentucky
    no but do you think that it would hit on the inside?
  5. rayzorsharp
    I don't think so. I'm running 275's on now mine but with 15X10" Centerlines with 4 1/2 back space. No problem on inside but an occasional rub on the outside. I'm going to drop down to 15X8 Weld Draglites. I wanna get rid of the rub (minor tire damage) and considered going with 255's but don't really want to. I'm running 4:30 gears which work well with the 275's. I'm afraid the 255's are gonna change the gear too much on me. I'm just wondering if the 8" wheels might tuck the tires in a bit more. These 10" one really push the side walls out a lot.
  6. mavmike72
    mavmike72 Member
    louisville kentucky
    i really just like the wide look on the rear but if i could do it without getting another wheel ill do that (because im cheepppp)
  7. 74mavCoryE.
    74mavCoryE. Member
    Alberta Canada
    1974 maverick 2 door 302V8 C4 Auto
    So would P225 75R15 be too big for the front? I have a line on some nice rims and tires from a mid 70's dodge police interceptor... I know the rims fit but I was worried about the front tires being too tall and rub on the fender when turning.
  8. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    Will these fit my 75 without any modification?
    205 - 75-14
    205 - 70-14
  9. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    you'll be fine
  10. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    too tall that equates to a 28.29 x 8.86
  11. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    biggest up front with no mods with no rubbing would be a 235-60-15 245-60s might have slight rubbing at full lock with a stock 15x7 with 4.25 bs
    so a jump to 4.5 bs or some front trimming will counteract that.
    245-60-15 rear is a definate fit with no rubbing issues
    may get away with 255-60 on a stock 7in
  12. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    Any problem with these sizes on a stock slot rim?
    Front 195 75 14
    Back 195 60 14
  13. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    yea you need a taller tire in the back..
    195-75-14 = 25.52x7.68
    195-60-14 = 23.21x7.68
    if you flop the 60s to the front it'll look aight but i think it's still too low
  14. Centerline
    Centerline Member
    Washington State
    1971 Ford Maverick Grabber
    I personally think your car and wheel/tire setup in the picture looks great. I think going to a Cragar SS, if that's where you're going, would be a step backward. I would suggest just lowering it about an inch in the back and 2 or 2-1/2" up front. Just my opinion. Also, you'll get tighter handling with that engine closer to the ground. Of course, then you have to worry about steep curb cuts and such . . . :p
    I switched out to 16x7 wheels all around with 215/60R-16 on back and 205/50R-16 on front. The ride is not as nice but it's tighter. One more thing I noticed is that the ruts in the road tend to pull you around a bit more if you have the lower profile tire. Maybe it's just me?
