tire to leaf spring distance...
Discussion in 'Wheels and Tires' started by 71gold, May 17, 2018.
  1. baddad457
    Never said I did. That wasn't part of the question.
    1985Foxbody likes this.
  2. baddad457
    I have these in that size on my utility trailer on 10" slots. They were too short to suit me on the Comet.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    :rofl2:
  4. Earl Branham
    Lugoff, SC
    Frank, did you already remove the bump stops from the frame rails? That'll give you a lot of room. I removed mine, and got over 1/2" more room. Just askin',
  5. 71gold
    yep...but that doesn't change the...tire to spring distance...:bouncy:
    Crazy Larry likes this.
  6. Earl Branham
    Lugoff, SC
    I guess you are right, just the frame to tire. How's things going over there? Constant rain here. Take care, call you later,
  7. satchelmcqueen
    satchelmcqueen Member
    north georgia
    I have close to 1/2". Running 15x8 4.25bs wheel and a 275/60/15 mickey Thompson tire.
  8. Xplane
    Xplane Member
    SoCal
    Lots
    If you are looking to make some extra room I'll be doing a tech write up soon on moving the leafs inboard with a much sturdier forward spring eye mount. With a rolled fender lip this will allow a 11.5" section width rear tire. I will be running a Hoosier quick time pro DOT 27x11.5x15 on a 9" rim.
    71gold and yellow75 like this.
  9. yellow75
    Tillamook Oregon
    That would be a good tech right up I am sure there are many people that would be interested in it
  10. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    1970 Maverick, 1998 Explorer Sport
    Yes, Yellow75 is right it will be a good tech right up and I for one am looking forward to seeing it...
  11. Xplane
    Xplane Member
    SoCal
    Lots
    I am having trouble getting the guy to water jet and send me the parts, but still working it. I will post some pictures of the install on his racecar.
    maverick306 likes this.
  12. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Have you had any luck getting those parts made for moving the leaf springs inboard?
  13. Xplane
    Xplane Member
    SoCal
    Lots
    I picked up an explorer rearend and it’s at the shop being shortened. I don’t have the relocation brackets yet but keep bugging Mike Bowen about them. He is running the NMRA series and working his shop by himself, so maybe a little overwhelmed.
  14. abesshop09
    abesshop09 Member
    Oceanside, Ca.
    Ok, I am keeping watch on this subject because I would like to move the leaf springs in a little to be able to run wider tires tucked inside wheel wells..
    Thanks for the update...
  15. baddad457
    You can gain some just by jacking the rear up and loosening the U bolts, then using a crowbar, pushing the springs inboard while retightening the U bolts.
