Tires opinion
Discussion in 'General Maverick/Comet' started by scs, Apr 14, 2016.
  1. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    Here is the final deal for new wheels and tires... done!!!! I gambled and downsized 1" diameter on the front and left the backs the same. Looking for opinions again. Maybe a 1/2 spring yet on the front (or not), but I think that can wait.
    Before:
    After:
    Paul Masson likes this.
  2. Dwarvey
    Dwarvey Member
    SoCal
    71 Ford Maverick
    I like. The new rims and tires look great. The old ones..........eh.
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    clearance permitting.. I'd "stuff the tire" just a tad more with another 1/2" down in the back(1/2" block).. 3/4" in the front(half coil should get you pretty close). Rake angle is nice and looks pretty decent either way you go though.
  4. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Looks great I think
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    What sizes are those?
  6. scs
    scs Member
    Prescott wisconsin
    OLD FRONT: 215/70R15 (26.85" diameter)
    OLD REAR: 235/70R15 (27.95" diameter)
    NEW FRONT: 215/65R15 (downsized to 26" diameter)
    NEW REAR: 235/70R15 (same as old, 27.95" diameter)
    All are on 15x7 rims with a 4" backspace. No interference except for a slight contact on the new CSRP dual piston front brake calipers which I will fix with a 1/4" or less spacer if I can find one.
    I went with the bigger rear tires since I have a 3.80:1 rear which is more than I need.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The difference in gear ratio with the taller tires would be barely noticeable.
    The front springs definitely need to be shortened a bit; perhaps 3/4 coil.
    Of course when you do that, the front will look right but the rake will be drastic with the 28-inch rear tires.
    If you can lower the rear some without rubbing issues, I'd suggest that, but what I'd really suggest is a 245/60-15 on the rear. They are nice & beefy and 26-1/2" tall.
    Your new front tires are a huge improvement.
    mav man likes this.
  8. scs
    scs Member
    Prescott wisconsin
    Thanks for the opinion. I will definitely put this put this on my bucket-list of changes, but out of impatience and lack of any more $, this is how it will look for a few years. I figure the rpm at 65 mph for this setup would be about 3000 rpm vs about 3150 rpm for the tires you recommended, yes minor. If I can ever afford a new 3.25:1 pumpkin, that would bring me down about 400 rpm to around 2600 rpm at 65 mph, much better. Maybe then new tires.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I said 26-1/2 inches "wide" (LOL). I meant tall.
    I doubt there is a 150 RPM difference between the two tire sizes. I understand you have to run what you can afford at the moment (I'm in the same boat).
    A 3.25 is a good choice without having overdrive.
  10. Craig Selvey
    Can you grind some off of the calipers in order to not have to use the spacers?
  11. scs
    scs Member
    Prescott wisconsin
    Yes. The piece that I would need to grind is the fluid connection between the two dual piston chambers, so you can see why I am not comfortable with this. I suspect there is plenty of margin, but with my luck, fluid would be present after the grind.
  12. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    265 rear and 205 front
    ike72com likes this.
  13. scs
    scs Member
    Prescott wisconsin
    Thanks for the picture. I can see why I am being told I should cut more front spring and drop my rear.
  14. groberts101
    groberts101 Member
    Minneapolis, MN
    Badass looking ride you have there. Love that stuffed tire and heavily raked look.
