To much voltage?
Discussion in 'Technical' started by smegnl, Sep 30, 2010.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    With a volt meter across the battery and the car running, it says it is putting out 21V ? With it of the battery is reading 17V. Doesnt that seem kinda high?
  2. Mavaholic
    Either your meter is screwed up or your going to fry that battery quick. First I'd find a fresh 9volt battery and check your meter.
  3. mojo
    Try another voltmeter. If u really have that much voltage I wud think u wud damage elec components.
  4. darren
    Your batt would be spewing acid everywhere.
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    OK, ill get a new 9v, mine does have a low bat warning showing on the meter.
  6. Mavaholic
    Measure the fresh 9v battery with the meter. A low meter battery should not alter the voltage readings.
  7. mojo
    Try another meter. :hmmm:
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Yep new meter says 14.4V.. Whew :clap:
    I have had the other one for like 12yrs.. Think its the only tool Ive been able to keep that long... :cry:
