To the bodyshop it goes.
Discussion in 'Cosmetic' started by rdog348, May 12, 2013.
  1. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    After setting in my garage for a year waiting to get an engine in it, I drove the Mav' to the shop today, with no 1st gear, bummer, but finally got there, gave it a good wash, and come to realize, it needed some body work, my Grabber hood was starting to bubble, and the quarters were starting to bubble, I opened the door, and found my cowl is finally leaking, so I need to find me some Mustang cowl patches, if anyone knows where to get them, please let me know! My car is an AC car, so I believe I need both sides.. Hopefully after getting my cowl, hood, and quarters done, I won't run into any other problems..
  2. 71gold
    is it the cowl or the windshield seal leaking?
    have you checked the floor pans in the front?
    A/C cars just have one hat on the pass. side.
  3. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    Thanks for the info about the top hats. Its the cowl. I checked by pouring water directly down it. My floor pans are solid.
  4. 71gold
    what's the plan for the cowl repair, there are a few different ways to do it?
  5. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    Since I don't have a solid donor I'm just going to use Mustang patch panels and coat it with POR15. Would adding a mesh behind the cowl grille help with leaves and other junk?
  6. 71gold
    I did a...cowl vent delete...:thumbs2:
  7. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    What's the finished project? I'm interested!
  8. Tannersg1
    Tannersg1 Member
    Classified
    What do you use for defrost and heat if its needed?
  9. 71gold
    work as always...
    A/C is on ...recirculate...:cool:
    you may not want to do this if you have a...non-A/C car.
  10. 71gold
  11. Dave B
    A/c cars only have the hat on the passenger side ( factory a/c)
  12. darren
    The heater will draw in air from the two large drain holes at the ends of the cowl behind fenders. Not sure if its a good plan for fumes etc. but it will work as normal in defrost.
  13. Tannersg1
    Tannersg1 Member
    Classified
    Thanks for the info guys! I don't have air and i do like the vented cowl look so its staying put. I was just curious how the deleted cowl would work.:Handshake
  14. 71gold
    not if you cap off the hat, it will recirculate...:bouncy:
  15. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I have a magnetic cowl cover on, haven't repaired the cowl yet, and my defrost works just fine. It's a little bit slower but it was never fast to begin with.
